4x4 v 2WD exhaust manifold
Old Sep 4, 2005 | 12:49 PM
vyper developments's Avatar
vyper developments
Default 4x4 v 2WD exhaust manifold
Hi All,
I was impressed with my friends 4x4 it picks up very quickly from low rpm due no doubt to a shorter exhaust manifold than 2WD therefore reducing lag. I realise that perhaps the 4x4 manifold would not ultimately flow as well as 2WD and also they do tend to crack but would this manifold work well on a stage 3 2WD engine in regards to a more responsive pick up?
CheeRS, Mike.
Old Sep 4, 2005 | 01:00 PM
Mr C's Avatar
Mr C
Lag difference is not usually noticable on 330bhp 4x4/2wd, so not worth the hassle I wouldnt think??
Old Sep 4, 2005 | 06:01 PM
Kelv's Avatar
Kelv
Almost there!
Big power engines do tend to use the 2wd manifold due to its ability to be able to flow that much more.... but mildly laggier.
but not that much of a noticable difference on a 330bhp spec engine!
Old Sep 5, 2005 | 09:31 AM
sailorbob's Avatar
sailorbob
I think 400+ bhp is the time to consider swapping to a 2wd manifold, the 4wd is fine upto there (and a little beyond).
Old Sep 5, 2005 | 06:39 PM
wimwerf's Avatar
wimwerf
YUM had 470bhp with a 4wd manifold.....
Old Sep 5, 2005 | 06:54 PM
sailorbob's Avatar
sailorbob
Did it glow nicely The 4wd manifold doesn't limit the maximum power (that I've heard of) but a 2wd flows better at higher bhp.
Old Sep 6, 2005 | 07:05 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the exhaust system can make a much bigger difference to the way that the turbo 'picks up' than the manifold.
you should also consider that 4x4 had a different turbo to 2wd that was designed to 'pick up' quicker
Old Sep 9, 2005 | 02:46 PM
steventoon's Avatar
steventoon
are the 4x4 and 2wd manifolds interchangeable ?
Old Sep 9, 2005 | 03:19 PM
G.Man's Avatar
G.Man
Yes they are...
You will have to give the turbo a twist tho
May 31, 2016 09:28 PM
mint_s2
Sep 2, 2015 08:58 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
