sapphire brakes
Old Sep 1, 2005 | 07:40 PM
andyrh's Avatar
andyrh
Default sapphire brakes
Hi there,
Sorry if this is an obvious question, but can someone tell me if the standard disks and calipers (f and r) from a 2 wd sapp cossie will fit the 2.0i dohc sapp.
Cheers!
Old Sep 2, 2005 | 01:05 AM
jon@work's Avatar
jon@work
No - neither front or rear unless you also change to cossie hub carriers.
Old Sep 2, 2005 | 08:23 AM
Dave Henshall's Avatar
Dave Henshall
saph and 3 door 2wd cos:
front: 283 x 24 vented
rear: 273 x 10.3 solid
saph 4x4 and escos:
front: 278 x 24 vented
rear: 273 x 20 vented
all this info andmuch more found on here....
quite a useful site with the cross refernece, pcs, holes etc in th electronic catalog...
http://www.webparts.co.uk/National/A...rake_frame.htm
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
