Brake disks - advice needed
Old Aug 31, 2005 | 05:48 PM
ROLL GOLD DICE's Avatar
ROLL GOLD DICE
Default Brake disks - advice needed
disks have been warped on my car for a while now. Was told when i bought the car they were cossie disks. Took it to my local garage and he had cossie disks delivered, but they were the wrong fittment to go on the hub? (i think).
1. did he possibly get 4wd disks instead of 2wd disks, and thats why they dont fit?
2. Will 2wd disks go on an rs turbo no problems i.e. straight on and no need to change calipers?
Old Aug 31, 2005 | 05:54 PM
ROLL GOLD DICE
and im asking question 2 because if the answer is yes, il get a set of 2wd disks and fit them myself
Old Aug 31, 2005 | 06:02 PM
cuvner's Avatar
cuvner
4x4 disks are smaller than 2wd disks, 2wd disks fit erst hub but i dont know about 4x4 disks??
No, u need too move caliper out to fit 2wd disks, 4x4 calipers 2wd disks is the easy conversion!!
Old Aug 31, 2005 | 06:19 PM
ROLL GOLD DICE
[img]C:\Documents and Settings\Jason Clarke\My Documents\Jasons Work\new pics\wheel1
anyone know what these disks are?[/img]
Old Aug 31, 2005 | 06:20 PM
ROLL GOLD DICE
duno how to get pics on here, but if anyone can help, il email you pics of my disks
Old Sep 1, 2005 | 03:24 PM
cuvner's Avatar
cuvner
heres you go!! Do 4x4 calipers fit erst hubs?
Old Sep 1, 2005 | 04:28 PM
Oranoco's Avatar
Oranoco
The calipers fit although need spacing by 8-10mm iirc. You also need 2wd discs not 4x4 ones.
Old Sep 1, 2005 | 04:40 PM
cuvner's Avatar
cuvner
sorry i meant to say do 4x4disks fit erst hubs? so is the holes pitched differently on 4x4 disks? ROLL GOLD DICE, didnt know if the disks he got wer 4x4 or 2wd ones, i surpose he cld measure um 2wd are 285mm and there would be no chance of fitting them under the erst calipers either!
Oranoco, ever bn to rye house speedway?
Old Sep 1, 2005 | 04:46 PM
Oranoco's Avatar
Oranoco
Can't say I have mate. Don't even know where it is
Old Sep 1, 2005 | 05:18 PM
AKRS1's Avatar
AKRS1
I think you cant fit 4x4 discs bcos they are smaller discs and i think you can use erst calipers with special made brackets
Old Sep 13, 2005 | 11:18 AM
PGT's Avatar
PGT
324mm rs focus fit with 16" wheels, require a bit of modding to caliper carriers
track.focus'd
Aug 12, 2015 05:53 PM
Jack and the Beanstalk
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
