How much are these worth?? Anti-Lag on 2WD Cos
Old Jun 30, 2004 | 07:12 AM
Mattie's Avatar
Mattie
Default How much are these worth?? Anti-Lag on 2WD Cos
How much would people expect to pay for these secondhand parts (in good condition)?
P8 ECU with ALS (including modded elbow / idle valve) - £?????
T35 Turbo with Maram Shaft - £?????
Air Injectors - £??????
Are there any mods required to run P8 ECU on 2WD Sapphire (ie. TPS)?
How does the T35 stand up to ALS (even with Maram Shaft)?
Old Jun 30, 2004 | 08:19 AM
JAP CRAP's Avatar
JAP CRAP
air injectors about 350-400 quid.
not sure about the others
Old Jun 30, 2004 | 08:40 AM
Turbo lag's Avatar
Turbo lag
How much do you want for the T34 and how much milage has it done?
cheeRS Dave.
Old Jun 30, 2004 | 08:55 AM
turbinator's Avatar
turbinator
Default Re: How much are these worth?????? Anti-Lag!!!!!
air injectors are no longer available.. so depends on how bad someone wants them i guess..
Yes there is 1 mod required to run the P8 on a 2wd...
Take the 2wd throttlepositioningsensor off the car and replace it with a 4x4 item .. or if you dont have those available, switch the 2 outside wires (3 wireplug) which connect to the throttleposiotingsensor..
(they work the other way around 0 to 5 v and 5v to 0 ... that all you need to do!
Old Jun 30, 2004 | 09:22 AM
GARETH T's Avatar
GARETH T
NO you need to swap the top and bottom wire AND fit the 4wd tps,,, the two tps work totally different!
editied as i wrote 2wd tps the first time
Old Jun 30, 2004 | 09:30 AM
Mattie's Avatar
Mattie
So, will a 4x4 TPS work without mods?
Old Jun 30, 2004 | 09:31 AM
GARETH T's Avatar
GARETH T
no you need to swap the top and bottom wire of the tps plug around
Old Jun 30, 2004 | 10:07 AM
CozzyBrom's Avatar
CozzyBrom
say that again plz mate
can i fit the tps no mods
Old Jun 30, 2004 | 10:10 AM
GARETH T's Avatar
GARETH T
Old Jun 30, 2004 | 10:16 AM
Mattie's Avatar
Mattie
cheers brom
Old Jun 30, 2004 | 10:47 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
http://www.randbmotorsport.co.uk/sho...p?ProductID=94
Old Jun 30, 2004 | 10:54 AM
NICK K's Avatar
NICK K
You can buy air injectors from Engine advantages for around 300 squid brand new
Old Jun 30, 2004 | 10:56 AM
turbinator's Avatar
turbinator
NO you need to swap the top and bottom wire AND fit the 2wd tps,,, the two tps work totally different!
maybe you should READ BETTER ..
he asked to fit a P8 on a 2WD so the 2wd TPS would already be on it would'nt it ???
Old Jun 30, 2004 | 11:06 AM
Mattie's Avatar
Mattie
So what about lambda?????
Mattie's Avatar
Mattie
Old Jun 30, 2004 | 11:09 AM
Ima-Racing500's Avatar
Ima-Racing500
I supply air injectors to most traders
I have a modded 2wd wrc anti lag throttle body..if of any use.
Old Jun 30, 2004 | 11:24 AM
GARETH T's Avatar
GARETH T
i fucked up there,, he needs a 4x4 tps sorry and swap the wires,,,
Old Jun 30, 2004 | 12:45 PM
turbinator's Avatar
turbinator
Sorry.. but you are wrong..
he doesnt need a 4x4 tps... only to swap the wires is sufficient..
I myself drive a L6(2wd) on an escort cosworth .. and all it takes is a wireswap!
both tps's do exactly the same...
Old Jun 30, 2004 | 12:59 PM
Stu @ M Developments's Avatar
PassionFords Creator
turbinator,
No it isnt. Not in any way.
turbinator,
No they dont, get your self a multimeter and try it for yourself.
Old Jun 30, 2004 | 01:08 PM
foreigneRS's Avatar
foreigneRS
Testing the future
i agree with gareth T. for l1and l6 ecu you need a pf01 2wd tps, for l8 you need a 4x4 pf09 tps and if fitting those to a 2wd wiring loom you need to swap the outer 2 wires around.
2wd and 4x4 tps do not work the same at all. they work the opposite way around for a start, so that one has maximum resistance at closed throttle and the other has minimum
Old Jun 30, 2004 | 01:09 PM
zvhturbo's Avatar
zvhturbo
Can you not fit either with the wires the correct way round then get the throttle stops re set by a tuner?
Old Jun 30, 2004 | 01:37 PM
Mattie's Avatar
Mattie
What about lambda sensor?
Old Jun 30, 2004 | 01:41 PM
foreigneRS's Avatar
foreigneRS
Testing the future
no-one in their right mind would pay more than a fiver for a secondhand lambda sensor.
Old Jun 30, 2004 | 01:42 PM
Mattie's Avatar
Mattie
Am not saying I am buying a secondhand one mate.
Just asking what is needed in terms of lambda control?
Old Jun 30, 2004 | 02:00 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you didn't make that clear...
an l8 or p8 ecu (or maybe others if Stu has had his hands on it) and a lambda sensor and a few wires
Old Jun 30, 2004 | 02:05 PM
Mattie's Avatar
Mattie
Sorry mate.
What I really meant is if I install a P8 ECU will i NEED some form of lambda control if using this ECU in a 2WD application
Old Jun 30, 2004 | 09:41 PM
turbinator's Avatar
turbinator
Originally Posted by Stu @ M Developments
turbinator,
turbinator,
We did... ?? there is no problem whatsoever...
We also run a 4x4 sierra with an L6 and its runs better then it ever did.. (also only wireswap ?) and it is on lambda readout and it shows no problems at all !
So please explain your finding, ofcourse I am willing to listen to reasoning why you think its not ok to do this ??
Al we found out is that it runs 0volt closed throttle to 5v open ..
and the other is exactly the other way around >> 5v to 0v..
yes resistance is different on closed throttle but it doesnt seem to have any problems with it and as I said.. runs very smoothly..
So is there something I overlooked ?
Old Jul 1, 2004 | 10:23 AM
GARETH T's Avatar
GARETH T
i think you should test the output voltage against throttle angle for both tps, and you will see a different
Old Jul 1, 2004 | 10:58 AM
Im a bit busy at the moment but if you check the PF01 output at idle you will find its actually completely open circuit which is what activates the idle and overun strategy in the management prom.
The strategy is different in L8 and P8 as they run a closed circuit resistance at idle and actually see open circuit, quite understandably, as a sensor failure.
Hope this helps.
Old Jul 2, 2004 | 11:27 AM
for Kennert.....
mark r
Sep 29, 2015 07:27 PM
`spotty
Sep 25, 2015 11:41 PM
PeterLucas
Sep 21, 2015 11:36 AM
coscor86
Sep 20, 2015 01:21 PM
Vincereese
Sep 17, 2015 10:34 AM
