Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
Custom inlet manifolds - 700+bhp capability (updated photos)
Old Nov 20, 2003 | 02:02 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default Custom inlet manifolds - 700+bhp capability (updated photos)
£350 delivered. Can supply 4x1000cc injectors to suit for £350 as well.
The OE ones are limited to the following bhp (in the main due to the restrictive elbow NOT the throttle body, which will comfortably flow 600+bhp).
2wd = 430bhp
4x4 = 450bhp
EECIV = 500bhp
This manifold removes the restrictive elbow, and due to it's unique design has a pressure difference across the cylinders on par with the OE set-up.
The engine MUST be live mapped with this manifold to deal with the extra air at all rpms this can give with the correct turbo.
Bolts to existing inlet trumpets (not included) and can accept standard throttle bodies or 3" ones (not included).
Available in the new year in highly polished finish (just right for all you bufties .
Also comes complete with throttle brackets now (as well as Cometic gasket and all bolts etc).
Old Nov 20, 2003 | 03:30 PM
SapphyMike's Avatar
SapphyMike
sweeeet!
Old Nov 20, 2003 | 05:25 PM
Danny B's Avatar
Danny B
What thinkness is the material Mike? on the moting plate for Throttle body and the outer
Old Nov 20, 2003 | 08:12 PM
RANJ's Avatar
RANJ
looks like tomas`s one
Old Nov 20, 2003 | 09:27 PM
cossy abuser's Avatar
cossy abuser
can you supply them in a rough finish so I don't have to polish it!
Is it a straight replacement for a standard 4x4 one Mike?
cheers
Si
Old Nov 20, 2003 | 09:42 PM
YODI's Avatar
YODI
Mike,
is there any advantage or disadvantage of fitting one to a 350hp engine???
I know there might not be any benefit but I wouldnt want any loses either.
Also, you sent my bits yet??
Cheers, Yodi
Old Nov 20, 2003 | 09:56 PM
BODGE's Avatar
BODGE
mike give it a polish m8
mark
Old Nov 20, 2003 | 10:06 PM
Danny B's Avatar
Danny B
your said to loose mid range on a low power car, but it's very similar to mineand I've been running it on my set up with T34 24psi boost and it's still good midrange and responsive, that with a low comp engine.
Old Nov 21, 2003 | 08:35 AM
Mike Rainbird
Caraholic
Danny,
Top secret...
Simon,
If you don't want one highly polished, you can always paint it as per the one I have at present.
Yes it it is a direct replacemet for a an standard Cosworth manifold.
Yodi,
You may get a small amount of response reduction on a small turbo (similar to when you fit a big intercooler), due to the increased volume.
Yes, you should receive before 12 today.
Old Nov 21, 2003 | 11:59 AM
cossy abuser
very interested
If I still have the car after Crimbo and you are still doing them I may be tempted
Old Nov 21, 2003 | 12:06 PM
Danny B's Avatar
Danny B
Top secret aye it was only out of interest, I know mine is up to the job it was made by a race cr and performance engineer
Old Nov 21, 2003 | 11:46 PM
BigBoost's Avatar
BigBoost
mike would i get any benefit runnin it with a t4 on a low comp spec?
Old Nov 22, 2003 | 04:52 PM
Mike Rainbird
Caraholic
Gain of 20bhp above 5500rpm when compared to EECIV inlet at same boost (not had chance to compare against RS500 type, which would supply similar improvements against a EECIV plenum I believe).
Old Nov 22, 2003 | 08:39 PM
Gav Diamond's Avatar
Gav Diamond
you have pm mate
Old Nov 26, 2003 | 11:32 AM
does it work ?
Old Nov 26, 2003 | 04:09 PM
Mike Rainbird
Caraholic
Yes, just check out every single big power Swedish car....
Old Nov 26, 2003 | 05:08 PM
Alg1k's Avatar
Alg1k
Dont they run autronic ecu to get the fueling right on each pot
as ive heared the air delivery as they come on boost is a bit
Old Nov 27, 2003 | 08:29 AM
Mike Rainbird
Caraholic
When tested on the dyno, there was no problem what-so-ever. The designer acknowledges that there is a few % disparity between the air flow between the cylinders, which, as you will know is the same with the standard set up (and hence why No.3 cylinder is always problematical, as it receives more air than the rest). This Swedish set up has less disparity, but still not 100% perfect. However, when throwing fuel in, just like on the 500 conversions, you won't have any problems.
Old Nov 27, 2003 | 12:50 PM
RANJ's Avatar
RANJ
6% inbalance
Old Nov 27, 2003 | 04:17 PM
Alg1k's Avatar
Alg1k
Old Jan 8, 2004 | 07:58 PM
So why don't you use it then Mike..........
Old Jan 9, 2004 | 06:46 AM
Gadget's Avatar
Gadget
Spanner monkey
Mike would you sell just the throttle cable bracket to be used with a standard throttle body?? i'm halfway through making my inlet and like the look of your bracket!!
cheers mate, Gary
Old Jan 9, 2004 | 08:08 AM
Mike Rainbird
Caraholic
Dan,
Because my remit was for stonking throttle response and what-ever power the turbo would produce @ 27psi, and so not a 700bhp engine . This meant that the volume of the EECIV plenum was ideal for the power that I ended up with and I didn't need the volume of a 700bhp plenum for a 400bhp engine...
Congratulations on your new job!
Gary,
Haven't got any brackets spare at moment, but when the next order comes over I will ask them to send an extra bracket over (will of course check with you first that you still need it).
Best regards
Old Jan 9, 2004 | 08:39 AM
Gadget's Avatar
Gadget
Spanner monkey
Thanks Mike, it's not true what they say about you.... don't listen to them
Old Jan 28, 2004 | 11:25 PM
Fiecos Dan's Avatar
Fiecos Dan
hi mike,
this mite be wot i need, doin a 500 engine and got to either get a 500 set up or this root. give me a bell on 07855377423 as dont get a chance to use the net much.
cheers danny
Old Feb 3, 2004 | 06:03 PM
But Mike you said you gain 20bhp above 5500rpm..so surely it would be worthwhile even on yours Plus with anti-lag...you wouldnt notice any difference
Tempted myself actually I need to get back into my cossie and remeber why the fuck i bought and modded it
Old Feb 4, 2004 | 04:31 PM
Mike Rainbird
Caraholic
Phil, yes but at a loss down the bottom, which I didn't want in my car and you'd get banged up if you had ALS on all the time as well as it exceeding lots of track's noise limits. I built a grunt monster, hence why the limit on the boost. If I had wanted just outright power, then I would have used one on my car, but the EECIV had the exact volume I wanted for the low down response.
Danny,
If you want to talk, the land line is detailed .
Old Feb 5, 2004 | 01:06 PM
Gadget's Avatar
Gadget
Spanner monkey
Mike, any throttle brackets yet?
Old Feb 5, 2004 | 02:05 PM
Mike Rainbird
Caraholic
Not quite yet, but imminently...
Old Feb 9, 2004 | 09:46 PM
Fiecos Dan's Avatar
Fiecos Dan
can you text me your number and i will give you a bell, on 07855377423.
cheers danny
Old Feb 10, 2004 | 01:46 PM
Mike Rainbird
Caraholic
01508 557 822 Landline 0800 to 1730 / 07771 91 22 91 mobile for when not on landline.
Old Feb 11, 2004 | 07:10 PM
looks like what I`m after, just wondering if it uses all std gaskets (throttle body and plenum)? What provisions does it have for pressure sensors underneath was it 4 or6 and what else is under there? And lastly where does this new cover sit above the original, is the angle from I/cooler to it very steep?Its a possible purchase, Thanks Mike.
Old Feb 13, 2004 | 11:23 AM
Mike Rainbird
Caraholic
Mr C,
Comes complete with all gaskets. Is custom built to whatever throttle body you want from standard to 4".
As standard there is four, but you can have as many as you want.
See pictures below for installation in car (thanks to John Woolley for taking them):
Old Feb 13, 2004 | 06:45 PM
Smart Mike cheeRS, looks spot on thanks for your time
Old Feb 17, 2004 | 07:02 PM
Mike, do they come with the throttle cable bracket or would i need to make that myself? (I would be using a standard throttle body)
and sorry to bug you but do you know if i would still be able to use my existing engine map or would this affect it to the point of needing a new one?
thanks.
Old Feb 18, 2004 | 01:33 PM
Mike Rainbird
Caraholic
Darren,
Comes with bracket.
No point in fitting if you don't do a re-map. This is a MUST.
Old Feb 18, 2004 | 03:29 PM
ok cheers mike. doh!
means that this will have to wait till i can afford a live map then
Old Feb 22, 2004 | 03:57 PM
cossie400's Avatar
cossie400
yep all you need is 2x 3" 45 degree samco bends cut down, still tight as fook though
Old Mar 15, 2004 | 07:22 PM
cossie400's Avatar
cossie400
Mine might be for sale if anyone is interested as i'm going a different route now, i got 503 bhp with this inlet and it also looks good well worth it. 07787 140652
Old Mar 15, 2004 | 07:31 PM
cossie400's Avatar
cossie400
£230 delivered 07787 140652
