Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
slow xr3i
Old Aug 29, 2005 | 02:18 AM
jason len's Avatar
jason len
Default slow xr3i
think its time a rebild soon as my car seems very very slow, struggles to get up hills most times, its a 1.8 16v 130 model so should have some poke
trouble is im curious to either rebuild or go for somethink alot quicker engine wize,
what you guys think?
Old Aug 29, 2005 | 09:19 AM
Paddy's Avatar
Paddy
Legend
For the price of a second hand engine, you might as well stick the 2.0 litre lump in it
Old Aug 29, 2005 | 02:38 PM
jason len's Avatar
jason len
well i know a guy who has a Ford 1.9 Zetec Engine Block and Pistons,
the block is 1.9 with forge piston, the conrod are design with floating gudgen pins, what ever that means , and there is no piston ring and you will need a new of mains and big end bearing, does this sound ok? also are the prices on new piston rings expensive?????
thanks
Old Aug 30, 2005 | 03:40 PM
jason len's Avatar
jason len
ok guys need some advice here,
after phoning around asking mates mates etc,
i have 2 choices, which would u say is the best to go for guys for turboing my zetec,
option 1:
the pistons need new rings and it also needs a new mains and big end bearing.
option 2:
2 litre zetec bottom end, complete with 1.8 sump,
set of used mahle forged pistons from a vauxhall xe, apparently told they will make it low comp, however i was told needs will need reboring to suit to give around 2050cc.
what do u think guys is best option?
thanks
Old Sep 2, 2005 | 02:55 PM
mart.rs's Avatar
mart.rs
didnt know they made a 1.9 zetec(or do you mean 1856cc,1.8) personally id go for the 2.0 ditch the injection and stick it on throttle bodys,add some uprated cams,a nice 4-2-1 manifold and system and a decent management and chip and bobs ya uncle you should be knocking on the door of 180bhp plus! and the 2.0 has more grunt!!!
Old Sep 10, 2005 | 12:15 AM
Paul_RS's Avatar
Paul_RS
option 2:
thanks
You don't want to go low comp with an NA engine!!
Old Sep 11, 2005 | 08:23 AM
Paddy's Avatar
Paddy
Legend
As RS nutter said, the low compression engine will be best suited to turbocharging so unless you're going that route, don't bother with it
stephenb4506
33
Oct 2, 2015 06:25 PM
A.t.p
Sep 29, 2015 05:04 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
