S2 Brakes
Old Aug 26, 2005 | 10:35 PM
dave_y's Avatar
dave_y
Default S2 Brakes
after a quick search i found that the best brakes to go for are the 2WD Saph brakes. Are these the right ones i found on ebay?
http://cgi.ebay.co.uk/FORD-COSWORTH-...QQcmdZViewItem
they are from Graham Goode so they must be alright?
also what is the going rate for these discs?
am i right in thinking they will fit under standard wheels?
any other advice for brake upgrades would be much appreciated
thanks,
Old Aug 27, 2005 | 06:46 AM
cuvner's Avatar
cuvner
just done the upgrade, you want 2wd disks with 4x4 calipers and carriers, if you can hang on a few days im getting some calipers so might be able to get some disks and sell you the lot if your interested! Deffinately get better pads, but atŁ70 bucks for 4x4 pads they aint cheap!! All this will fit under 15" standard wheels unless you got massive wheel weights on the inside of your rim! excellent braking once bedded in properly
disks/pair
Ebc=200
standard=90
Old Aug 27, 2005 | 03:42 PM
dave_y's Avatar
dave_y
that sounds cool. are you local?
i take it they aren't knackered at all. also are they genuine ford jobbies?
if there are huge weights on the inside of the wheel i will get them moved.
bigger brakes are much needed lol.
Old Aug 27, 2005 | 05:19 PM
cuvner's Avatar
cuvner
dorset!! i got courier service at work so sending aint a problem! i will see what i can sort for ya!! genuine calipers all working hopefully, i will test um on my car or sumfn, if all fails you can get the kit through zoo motorsport!!
Old Aug 27, 2005 | 05:25 PM
dave_y's Avatar
dave_y
ok mate that sounds cool. keep me posted
Old Aug 27, 2005 | 05:53 PM
Rab's Avatar
Rab
Fucking superstar........
the 4X4 ran 1 pot calipers............. You'd be better off with your S2 calipers. Best ones to use are the 2wd calipers cos they're 4pots.
HTH
Old Aug 27, 2005 | 05:56 PM
cuvner's Avatar
cuvner
why do people not go for the 4pots then? must have different pitched holes on the carriers and dont fit the hub or sumfn? You still get bigger pad area with the 4x4 calipers though, i would of gone for the 4pots but advised not too!!
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
