here's a few pictures of mk1 cossie i've been building over the last year an half. it has had a full strip down and rebuild and painted imperial blue. the arches are all steel,had new floor pan and inner sill fitted along with new gearbox tunnel and four link boxes. also had new front panel and slam panel. suspesion-bilstien coilovers all round,adj tca's,compression struts,5 link rear end. brake's- front 300mm disc's and 4 pots, rear cossie 4x4 disc's and calipers on capri 2.8i axle. rear cage, bucket seats.............just got my new side exit exhaust,some more silicon hose's and a new spal electric rad fan and sensor. should keep me busy for a couple of days
Twins, do you know how to get photo's from photobucket on to here
yes if you click on the uploader on the passion ford page above the logo ,this will take you in to photobucket while still on passion ford ,get to the picture you want to transfere below is the word img ,put your mouse in the white box next to these words and left click the mouse then right click ,you will have a box come up ,then click the copy ,at the bottom of the screen click back on passion ford brings you back to the screen were you are replying ,then left click right click mouse and click on paste ,you will have a file come up with [img] at both ends repeat for every pic ,hope this helps always start a new line with a pic or they ill be all over the place
Well worth typing out them instructions ,that is the nuts ,what will the engine be making and will it be using a turbo or na (Edited to say prob turbo looking at the bonnet louvres )
will be running about 400bhp +. engine is rebuilt using new 1mm oversized pistons, new shells, wrc head gasket, arp stud + nut kit, greys, garrett super T70 turbo with external wastegate and a few little secret mods
i haven't got any pics of under the bonnet yet. waitng for my turbo to be delivered next week. people say the wheels look to big and some say look good. i have now changed them for a set of group A cossie 8x15 rfx revolutions painted white with polished rim. will get some more pics soon
the turbo is a monster. it's a garrett super T70. it has a .84 ar exhaust housing, a ar 70 compressor housing and is twin roller bearing with external wastegate
just bought a tubular stainless manifold to go on the mk1. hopefully will arrive next week from finland. i'll put some pictures of it on here when it arrives
