205 block id
Old Aug 25, 2005 | 04:47 PM
briansnelling's Avatar
briansnelling
Default 205 block id
i presume i have a genuine cosworth 205 block with yb number stamped just above water pump.i also have 2 inj pinto 205 blocks.above the distributor hole on the cosworth block is stamped 2222 also on one of the pinto blocks,the other pinto block is stamped 3333.i was once told this related to the thickness of the cores is this correct.
thanks brian
Old Aug 25, 2005 | 09:14 PM
cossied's Avatar
cossied
Default block
it will say 205 under the exhaust manifold the 2222-3333 are the bore size tollerance for bores 1-4. the pistons come in the same grade numbers you can find the sizes in the Cosworth manuals.
Old Aug 25, 2005 | 09:18 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Try here
https://passionford.com/forum/viewtopic.php?t=63056
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
