AFR Gauges and lambda sensors
just brought a autometer afr gauge what lambda do i use
can i use one i have here which is for a zetec fiesta will it work the same??
all narrow band lambda sensors work the same, be they 1 wire (signal only), 2 wire (signal & earth), or 3 or 4 (with heater).
so yes it will work. won't tell you a lot though, just give you some dancing lights.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
