Whats needed to fit 18's on a saff
Old Aug 22, 2005 | 08:16 PM
richard_xr2i1800's Avatar
richard_xr2i1800
Default Whats needed to fit 18's on a saff
Hello what work is needed to fit 18's on my 2wd saff i have seen some wheels i like, do they go straight on also what offset do i need
Rich
Old Aug 25, 2005 | 09:31 PM
jaimesdna's Avatar
jaimesdna
hi you'll need a jack & a 19mm socket on a braker bar. na seriously i got 18s on mine & all i had 2 do was roll the front arches (with a dirty big hammer)not to sure what offset you'll need though
Old Aug 26, 2005 | 07:27 PM
W4SIM's Avatar
W4SIM
jaimesdna - How on earth did you EXACTLY roll your front arches then? I need to roll mine aswell, front and rear, but no 1 wants to touch the fronts as apparently the wing is too soft to take it.
But iv just gone over a bump and its bought the lip of the front arch outwards and nearly shredded the tyre aswell. But with me, sending the car back upwards is not an option, the fronts must therefore be lowered. But i want to know exactly what procedure you used and wether it caused any damage to the wing itself or the paint etc etc???
Cheers mate.
Old Aug 30, 2005 | 08:43 PM
jaimesdna's Avatar
jaimesdna
it was a bit of trial & error really. i started off bending the arches with a pair of mole grips as much as i could, then sat inside the arch with 1 hand firmly on the arch & just kept workin round the arch tappin it with a hammer till the arch comes back onto the wing. then primed it & seam sealed it to the wing to stop dirt & crap gettin in. its much easer if you scrape the paint b4 you start (the paint will flake off where you bend it as paint aint as bendy as metal). some people have told me that that put loads of cuts into theirs first with a grinder so the metal bends easer. its only a job you should try yourself if your really confident coz its reall easy to balls up, then youll need a new wing & paint (& worst of all having to explain 2 a profesional what you did to it ) mine have been done for a while now with no problems at all (& im running 8j rims) hope this helps p.s. i didnt need to roll my rear arches coz with all that negative camber the wheels clear them.
Old Sep 2, 2005 | 09:57 PM
CosKev3's Avatar
CosKev3
My m8 has just fitted a set of 7x18 inch RS GT's with 215/35 tyres with no probs at all
They clear his 330mm AP's too by a long way
Old Oct 6, 2005 | 06:17 PM
collierm's Avatar
collierm
MP for K.I.S.S
18's on mine no problem. Lowered on Koni's as well. Same tyre size as CosKev3. Hurts when I have to buy tyres though
mk22door
49
Mar 26, 2022 07:15 AM
James Porter
Aug 14, 2015 12:43 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
ricky
Jul 31, 2015 10:30 PM
