charge carrier and rocker cover help
Old Aug 22, 2005 | 04:09 PM
SamERST's Avatar
SamERST
Default charge carrier and rocker cover help
How hard are these to remove ? I have a polished charge carrier waiting to fit plus i wanna give my rocker cover a couple coats of paint. Is there anything when removing these i should know ? Should i also replace the rocker cover gasket ? Remember im new to this ford thing lol
Any help appreciated
Thanks
Sam
Old Aug 22, 2005 | 04:15 PM
FiL_FeZ's Avatar
FiL_FeZ
to bollts holding the charge carrier and summit like 10 bolts holding the rocker cover and thats it mate
and yes change the rocker cover head gasket
Old Aug 22, 2005 | 04:25 PM
SamERST's Avatar
SamERST
Cheers mate thanks for help, so what do i ask for "a rocker cover head gasket" ?
Also is there a torque setting or just do em up as tight as i can lol
Sam
Old Aug 22, 2005 | 04:59 PM
FiL_FeZ's Avatar
FiL_FeZ
yup just ask for that and remember to get gaskes sealer
and no there isnt any torque settings
Old Aug 22, 2005 | 05:00 PM
lith's Avatar
lith
yes mate try if poss to get a ford one. i think they are about 20 quid
Old Aug 23, 2005 | 08:57 AM
alan rainbow's Avatar
alan rainbow
Old Aug 23, 2005 | 09:11 AM
mart.rs's Avatar
mart.rs
yes also undo the 13m bolt on on the accelerator bracket (theres 2 infact and its the one on the right if your standing on the right side of the car) so it allows easy removal of the rocker cover!
Old Aug 23, 2005 | 10:10 AM
James Raby's Avatar
James Raby
Rocker gaskets are cheaper than that - I have one here I can send to you for Ł10 incl post if you want?
Genuine Ford one too
I would personally get the rocker cover powdercoated and normal heatproof paint will eventually crack and look horrid
when replacing rocker cover gasket, make sure all the surfaces are clean and definately make sure you don't tighten it too much as oil starts to seep out
Old Aug 23, 2005 | 05:55 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
get a 1.8 cvh gasket as they are rubber and better, the cork 1's are shite
and when u take the rockercover off make sure the bolts and spacers are in a tub and not laid on it in the recess
ur bound to dump em all in the head when the seal goes as ur pullin it off
Old Aug 23, 2005 | 06:10 PM
AJC's Avatar
AJC
powder coat the rocker cover instead of painted by hand, will look lot better
Mark RS
Mar 5, 2021 06:08 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
deathrider666
Sep 28, 2015 06:12 PM
