L8 ECU
Old Nov 19, 2003 | 07:55 PM
Default L8 ECU
L8 ECU what are the advantages ????
Im running greens, stg 3 etc on a 3door cosworth
Do these plug straight in ??
Any help would be mint
Old Nov 22, 2003 | 05:19 PM
Please Help
Old Nov 22, 2003 | 05:22 PM
Stu @ M Developments's Avatar
PassionFords Creator
They are a much better, smoother and more reliable ecu, but you will have to mod the loom, buy a TPS and a new chip.
Old Nov 22, 2003 | 05:51 PM
B11GNS's Avatar
B11GNS
Sorry to jack the thread but would you not have to change as much if you used a L6 instead of a L8?
Old Nov 22, 2003 | 08:59 PM
Which cars have which level ECU's ??
Old Nov 24, 2003 | 08:11 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
3drs L1
(some 3drs)RS500 L6
2wd saff L6
4wd saff L8
big turb escos P8
pissy turb escos Ford EEC-IV
L6 in L1 ECU`d car:
new chip
L8 in L1/L6 ECU`d car:
4x4 TPS/ new chip
P8 into all except pissy turb Escos:
TPS/ chip
P8 into EEC-I4 escos:
hahahaha, full harness/sensors etc, dont bother unless you got 3k wanting to be given away!
EEC-IV into any of above........ dont bother, i`d only suggest putting this in the bin
Old Nov 24, 2003 | 08:31 PM
i beg to differ but to fit a L8 ecu into L1/L6 car simply reverse the 3 tps wires.done it on my own saff and its been running 4 years like that!! (with an appropriate L8 chip obviously which i got from motorsport developments)
Old Nov 24, 2003 | 09:37 PM
Cossie Sean
yes your right mate, that is the gash way to do it,
i dont go round advising people to butcher the wires lol
Old Nov 25, 2003 | 01:51 AM
RS500/364's Avatar
RS500/364
RS500 L1
Old Dec 4, 2003 | 07:29 PM
the original's Avatar
the original
when you swap the outer wires round, can it be done in the ecu plug or must it be at the tps end, i.e do the wires from the ecu go only to the tps or do they split?
reason i ask is i can't get the tps plug apart and don't want to cut wires, but ecu plug pins can be prised out easily
Old Dec 4, 2003 | 07:45 PM
the original
also i believe as stu says, you need to change the wiring AS WELL AS fitting a pf09 4x4 tps, as i fitted the pfo9 and l8 but secs monitor still shows throttle going from 0% to 100% full throttle but if you set it (secs) to 4x4 tps it reads backwards.(with pf09 on 2wd loom)
help
Old Dec 4, 2003 | 08:01 PM
the original
just found the diagrams, loom can't be modded at ecu end, must be done near the tps as the wires are used for other things. better get the scotchlocks out
Old Dec 6, 2003 | 05:23 PM
big_wig_074's Avatar
big_wig_074
nah,just tape em!
Old Dec 14, 2003 | 09:54 PM
the original
got my l8 on and working now, does seem a lot smoother...
Old Feb 23, 2010 | 07:12 PM
gartracdriver's Avatar
gartracdriver
Question
sorry guys. what's a tps?
Old Feb 23, 2010 | 07:30 PM
bad boy rs's Avatar
bad boy rs
throttle position sensor
its the red one on the throttle housing
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
