ERST parts - NEW 2wd rear Calipers...
MY RS TURBO HAS JUST SOLD SO ALL THE PARTS ARE NOW FOR SALE.
UPDATED only parts now left
*90 spec recaro full interior, seats, front and rear door cards, the drivers seat has wear marks on. Door cards starting to sag on arm rests. £100
*90 spec front and rear door cards, very good condition £offers
*Stainless steel Fusion Fabrication K&N air filter heat sheat, as good as new £20
*REAR END SETUP, REAR ARMS, TIE BARS, HUBS IDEAL FOR POWDERCOATING £OFFERS
*NEW one off made turbo heat sheild, proffesionally made for the new large front mount pace intercooler, possibly can be used for all reverse charge carrier setups £30
Standard T3 turbo, water/oil coooled, needs re-conditioning, ideal for an exchange £40
Originally Posted by adamS2RST
Are any mods needed for the coil overs?
Originally Posted by sam wyatt
Hi mate i take it this is for the rear ?
New rear polished strut brace made by Fusion Fabrication. never fitted, its the biggest one he does 64mm (2.5") diameter. £45
No mods needed they bolt straight on... I would recommend having a rear strut brace thou.
the coilovers change the suspension at the back from a seporate spring and damper to havein the spring and damper as 1, so theroy is the rear end needs to be a little stronger to cope with this difference have heard of welding up the rear, strutbraces and such...
500 for the gaz's not bein a cóck but they are cheaper from a few retailers... u willing to negoate on that price
Mate if you could kindly post it to me for £40 cheque will be in the post monday morning
Got any pics of the items below and how much for the whole lot?
*Brand new in the box Genuine Ford Cosworth 2wd rear calipers left and right side, these are absolutly spotless, bought from ford a few months ago, also with brand new carriers. £offers
*New boxed aftermarket 2wd rear discs, not sure on the make, il get some more details, new in the box £35
*TRW set of 2wd cosworth rear pads £offers
Originally Posted by whiteRSTubby
mark why did you take the turbo heatshield off? did it not fit very well. Can you pm me if you still have it. Cheers
Originally Posted by JamesA_RST
not too heavy are they! That just for the Turbo or for the housing as well?
Mark, I once sent turbo on manifold for £15 mate @ post office so will be about £13 with www.parcel2go.co.uk or www.postvan.co.uk
cheers!
Oct 9, 2015 07:38 PM
155lee
Sep 14, 2015 07:37 PM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
il pm you....!
