Some pics of my cousins Performance Ford featured XR2 turbo
Heres some pics of my cousins XR2 turbo, the owner since it was in the mag has changed to my cousin
Spec
Fiesta rs turbo engine
Piper x induction kit
Cosworth piston dump valve
Pace cooler
Escort cosworth fuel pump
Vibratechnic engine mounts
-31 actuator
Escort cosworth 2.5 bar map sensor
Beige 701 injectors
Stage 2 chip
T2 hybrid 360 thrust bearing turbo
Cut back blades
Built in swirl pot to rs turbo fuel tank
Fse power boost valve
Spax suspension
Fully adjustable dampers all round
Lowered 50mm
Front strut brace
Hi spec motorsport 285mm cross drilled discs
Cosworth recaros
Custom made side exit exhaust
Standard rs turbo gearbox without lsd
Its best 1/4 mile time so far is 14.5 @ 99mph
Spec
Pace cooler
-31 actuator
Beige 701 injectors
Stage 2 chip
Cut back blades
Spax suspension
Lowered 50mm
Front strut brace
Cosworth recaros
rich w - very slowly mate
Just sourced a .63 exhaust housing...Need to get a decent exhaust system sorted out...Don't suppose you got any numbers for custom built ones tube torque etc?
Gets off the clock nicely I see
Just sourced a .63 exhaust housing...Need to get a decent exhaust system sorted out...Don't suppose you got any numbers for custom built ones tube torque etc?Gets off the clock nicely I see
MarK4
Never used this guy, but he aparently does a lot of kit car stuff. So it would be one offs
Mike The Pipe
128 Stanley Park Rd,
Wallington,
Surrey
SM5 3JG
Phone: 0181 669 1719
Heard a rumour hes stopped actually, but I havent confirmed it
RSR Tyres in Croydon and Sutton are apparently Powerflow makers. Again never used either
Mike The Pipe
Wallington,
Surrey
SM5 3JG
Billy_RS
16
Oct 11, 2025 09:41 PM
The Underdog
29
Sep 7, 2015 09:49 PM
