cosworth crank..
Old Aug 19, 2005 | 05:52 AM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
Default cosworth crank..
how many times can you get away with regrinding a cosworth 4x4 crank ??
Old Aug 19, 2005 | 10:10 PM
rs graham's Avatar
rs graham
someone must have a idear??
Old Aug 20, 2005 | 12:42 AM
Alvyn's Avatar
Alvyn
think it goes .25 .5 .75 then after that the shells are ONLY available in Pinto's etc! SO 3 times IMO
Old Aug 20, 2005 | 08:25 AM
Mr C's Avatar
Mr C
Typical tuners sizes are .50 Max, PJ wouldnt recommend i use any more than that. Ford do shells of the shelf at .75 though and not heard of anybody use bigger than that in a cosworth YB I am using .75 now so is there anythin to be done with the crank on my next rebuild or is it scrap??
Old Aug 20, 2005 | 09:01 AM
Alvyn's Avatar
Alvyn
[quote="Alvyn"]think it goes .25 .5 for Cossie's and .75 are a Pinto size shell IIRC
although a few people have used the .75 shells in Cossie application it's NOT recommended by tuners when in big powered lumps if that helps
Old Aug 20, 2005 | 09:47 AM
rs graham's Avatar
rs graham
alvyn,mr c, thanks for you help guys.
cheers.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
