17's 0n a series 1
Old Aug 18, 2005 | 04:32 PM
mark@fordrs.org's Avatar
mark@fordrs.org
Default 17's 0n a series 1
what will fitting 17's to my s1 take do i need to cut the body kit or any thing like that? the cars on koni 25m springs and dampers
Old Aug 18, 2005 | 05:04 PM
Oranoco's Avatar
Oranoco
Depending on how much ICE you have there should be minimal if any trimming of the kit required. I've done nothing to my S2 with a 35mm drop and it only catches if I'm braking hard and hit a bump at the same time.
Didn't catch at all even when driving like a mad man at Bedford
CliffS1 who posts on here has a S1 with 17" Voodoo's might be worth dropping him a PM.
Old Aug 18, 2005 | 05:18 PM
nigel b's Avatar
nigel b
7.5x17" and 215/40 tyres i had to trim abit off the arches/bodykit
if you go for 7x17" and 205/40 chances are you will have to trim a slight amount
Old Aug 18, 2005 | 05:51 PM
RSTEVE's Avatar
RSTEVE
i run 17 's 205/40 tyres in my mk3 cab with -35mm pi springs rubs on full lock but other wise fine , gotta watch out for those bumps.
Old Aug 18, 2005 | 05:54 PM
AJC's Avatar
AJC
i trimmed all 4 arches, thats lowered 40mm and 7.5 x 17, check the signature
to look
Old Aug 18, 2005 | 05:57 PM
gus's Avatar
gus
i only trimmed a very little off mine
thats a 7j wheels with 205's
Old Aug 18, 2005 | 11:32 PM
escort frenzy's Avatar
escort frenzy
I only had to trim off mine. I've got 7.5Jx17" with 205/40 R17's
Old Aug 19, 2005 | 09:24 PM
dry's Avatar
dry
I have 7 x 17's on 205 x 40's. Car is lowered ( dunno by how much ). They only catch on full lock and when hittin a bad bump on a bend.
Old Aug 20, 2005 | 07:39 PM
wul young's Avatar
wul young
i didnt have to trim mine with 7,17s with a 50mm drop,only on hard lock did they scuff the inner wheelarch,now using 7.5 17s ford rs wheels and i had to take about half inch of wheelarches,thats with 60mm drop on konis.
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
Bransby
Sep 11, 2015 01:09 AM
