Would a group A coil stop my spark being blown out?
I had my boost raised last week and my car is now backfiring / cutting out for an instant when on peak boost. When I was having the boost raised there was a severe misfire due to the "spark being blown out", this appeared to have been cured by new plugs/leads/dizzy cap, but it appears not totally.
I have not had the boost raised significantly (it peaks at 13 PSI and then drops down to 10-12) so I cant see that special plugs should be needed. Therefore I wonder what else I should look at in terms of wiring etc. I have also read about something called a group A coil which increases spark intensity. Would one of these help me?. What other things could be wrong with the ignition system?.
Any advice would be welcomed, I want to try and fix this myself if I can.
Best Regards,
Stuart
Best Regards,
Stuart
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
