s2 no compression
Old Aug 16, 2005 | 11:38 PM
Piinko-RS's Avatar
Piinko-RS
Default s2 no compression
allo guys a mate of mine has been doing a bit resto on his s2 this included a kent cam and stage 1 head plus abasic strip down on the engine , now he has put it back together and has no compression, i poped over and checked the timing and put a compression test on 1 and 2 pistons and nothing the needle didnt even move,
i was asking him which way he done it and it seems that he has done it ok . However he did say the head was moving a bit when he put it on it didnt slot in , so i checked his old head and the dowels which line the head up are still in there and he said there isnt any in the new head,
So just thinking if its not 100% lined up would this cause no compression ?
or ???
thanks for any help
Old Aug 17, 2005 | 12:24 PM
Oranoco's Avatar
Oranoco
Was the head changed for a new item. I would almost put money on the fact that he forgot to transfer the shims that sit underneath the rockers across. When this are forgotten it the rockers will keep the valves open and cause no compression.
It's what Rachel did on her 2i and it took me an age to suss it out
Old Aug 17, 2005 | 12:51 PM
GrimmeRS2K's Avatar
GrimmeRS2K
headgasket installed properly?
Old Aug 17, 2005 | 03:16 PM
turbo.jon's Avatar
turbo.jon
do sound like this as my mate done same thing when rebuilding his head
Old Aug 17, 2005 | 11:13 PM
Piinko-RS's Avatar
Piinko-RS
yep it was that he forgot to put the shims in , i left him a note to leave the old head out this morning when he went to work and sure enough they were still sitting on the old head , put them in and started on the 4th turn of the key ,,
cheers lads
Old Aug 18, 2005 | 11:29 AM
Oranoco's Avatar
Oranoco
Yay I got something right
Old Aug 21, 2005 | 01:16 PM
Series 1 van's Avatar
Series 1 van
a hear u got sorted its jason u get parts off my mates got good advice hope it helped get sum pics on av got my van and cabby on
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
