Sapphire 4x4 not boosting
Old Aug 16, 2005 | 08:10 PM
Adz 131's Avatar
Adz 131
Default Sapphire 4x4 not boosting
Hi all
Having major problem's with the turbo not boosting correctly
Car is running stage 3 pectel 803's usual st3 conversion.
Fitted recond turbo set actuator.
Amal valve replaced with GG racing uprated.
All hoses checked all ok.
Any suggestion's what could be causing this problem?
Best regards
Adz
Old Aug 17, 2005 | 02:05 PM
Adz 131's Avatar
Adz 131
Anyone got any suggestion's
Old Aug 18, 2005 | 12:36 PM
Big Man's Avatar
Big Man
Default Boost
Was the actuator adjusted from the old one or was it a stright swap? Try winding it in a few turns and test drive to see if she builds boost, I take it the wastegate arm could move freely on the new turbo?
cheers sean
Old Aug 18, 2005 | 07:48 PM
costina's Avatar
costina
Live long and prosper!!
Do you have a Dump valve?
is it sticking open?(piston type)
Or has the diaphragh split?
also check intake manifold gasket for leaks, have seen them blow
out
Good luck
Old Aug 25, 2005 | 11:31 AM
rog's Avatar
rog
Yeah stop being a homo shirt lifting fag.
Old Aug 25, 2005 | 04:09 PM
cossiegreg1's Avatar
cossiegreg1
What condition is your turbo in???
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
rog
Sep 16, 2015 03:00 PM
tib2220
Sep 14, 2015 12:33 PM
Marino
Sep 12, 2015 11:10 AM
Adam Graham
Sep 6, 2015 06:04 AM
