big brake kits??
Old Aug 15, 2005 | 03:19 PM
cuvner's Avatar
cuvner
Default big brake kits??
i really want a big brake conversion, wilwood do a 283mm kit £460 but i got to buy pads hoses and fluid, i was quoted a 4x4 cossy conversion for £520 everything in apart from hoses, or do i just get a bracket conversion and keep my calipers just run bigger disks? Real confused ? Whats the best alround, sensibly priced brake conversion for a s2?
Old Aug 15, 2005 | 03:43 PM
mart.rs's Avatar
mart.rs
mate look on e-bay or in newspapers,the loot.......etc you will pick up a pair of cossy calipers from a saff 4x4 for around 80-100 quid the discs you can get from any local motor parts store 80-100 pair ,(make sure their 2wd ones) and 4x4 pads too (40)whole lot should cost around 300 tops! job done! fitting is easy mate!
Old Aug 15, 2005 | 03:53 PM
James Raby's Avatar
James Raby
Go for the kit Gadget used to do, not heard anyone say anything bad about em
Old Aug 15, 2005 | 03:58 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Don't go near Wilwood.....
What kind of power have you got, and what do you use the car for? I think you will find that a Cosworth set up all round will be fine for fast road use. It's only on the track you will need something a bit more beefy, like AP's.
Old Aug 15, 2005 | 04:00 PM
James Raby's Avatar
James Raby
Wilwood are pants, as we all found out with mine - couldn't stop a damn thing
Tony, AP's as we know are the daddy - or custom Brembo's like Christian and Phil has/had
Old Aug 15, 2005 | 04:28 PM
cuvner's Avatar
cuvner
got bout 200bhp, gunna do a bit of track time so need something that can take abit of abuse! with the cossy set up do i need to make up some brackets or do they fit straight on the hub?
Old Aug 15, 2005 | 04:30 PM
James Raby's Avatar
James Raby
www.zoomotorsport.co.uk
Old Aug 15, 2005 | 05:41 PM
cuvner's Avatar
cuvner
cheers for that, gave the guy a ring and he sorted me out with a complete cossy setup!
Old Aug 15, 2005 | 05:52 PM
James Raby's Avatar
James Raby
No problem
U mean Gadget or Brom?
Old Aug 15, 2005 | 05:59 PM
cuvner's Avatar
cuvner
who's gadget or brom?
Old Aug 15, 2005 | 06:07 PM
James Raby's Avatar
James Raby
brom @ zoo
gadget as suggested above
So who's supplying the brakes mate
Old Aug 15, 2005 | 06:14 PM
cuvner's Avatar
cuvner
ah, zoo motorsport, cant wait to feel the difference, at the end of the runway at santa pod i cld feel my brakes fading so bad! new fluid and braided hoses i think too! just polybushed my whole car so its handling like a dream, chuck it into any corner and it slides in no understeer at all also it corners alot quicker too you feel the wheels gripping better!! wiv me new brakes too im going to be buying some track time!!
Old Aug 15, 2005 | 06:15 PM
James Raby's Avatar
James Raby
Please for you mate, hope all goes well
Old Aug 15, 2005 | 06:34 PM
NUTS RuS's Avatar
NUTS RuS
for Brom
Do you still have the ABS fitted ? Most people report better brakes if its removed
Old Aug 15, 2005 | 06:36 PM
James Raby's Avatar
James Raby
Tony, give the lad the low down, I'm sure he can do it
Old Aug 15, 2005 | 06:54 PM
NUTS RuS's Avatar
NUTS RuS
low down James ?
Old Aug 15, 2005 | 06:56 PM
James Raby's Avatar
James Raby
yeah, REALLY loooooow lol
i.e how to do it
Old Aug 15, 2005 | 07:30 PM
NUTS RuS's Avatar
NUTS RuS
He may already have it done
Old Aug 15, 2005 | 10:31 PM
cuvner's Avatar
cuvner
yea its still on, i had a gander at the abs the otherday, i bled the modualtors but didnt notice ne difference, if i rip it off im guessing il av to fit another servo unit and master cylinder, theres loads of pipes coming off the abs! just bn playing around in me motor and the rear locks up wen i hit breaks mid corner, great fun sliding around backing it in to corners but a tad dangerous if i got to use my breaks in an emergency
Old Aug 15, 2005 | 11:29 PM
NUTS RuS's Avatar
NUTS RuS
Better get that sorted then before you kill it
Old Aug 16, 2005 | 01:04 PM
CARL B RST's Avatar
CARL B RST
What size wheels have you got?
I've been considering cossie brakes, but i weren't too sure if they would fit ok under 15's.
Did it come with calipers etc aswell, or did you just fit bigger discs?
Old Aug 16, 2005 | 04:30 PM
cuvner's Avatar
cuvner
i got 15's i hope it will fit under! wilwood 300mm fit under 15's, if it dont i will just machine a bit off the caliper but looking at the wheel theres about 30mm clearence on radius so im sure it will be fine, calipers carriers disks and pads, you av to space the carriers from the hub using washers though!
what to do about this abs? is it difficult to remove?
Old Aug 16, 2005 | 04:36 PM
lutonmike's Avatar
lutonmike
how much did that set you back for the whole cossie front braked conversion??
Old Aug 16, 2005 | 04:40 PM
cuvner's Avatar
cuvner
£300, seems like a pretty gd deal recon calipers are 195 sterling pounds!
Old Aug 16, 2005 | 05:01 PM
lutonmike's Avatar
lutonmike
wow thats not bad i think i mite be giving them a ring tommorrow. so its the cossie 4x4 calipers,pads, 2wd 283mm discs and brackets??
Old Aug 16, 2005 | 05:53 PM
cuvner's Avatar
cuvner
you got it
Old Aug 16, 2005 | 06:04 PM
lutonmike's Avatar
lutonmike
but there only standard discs and pads but they'll be ok wont they?
Old Aug 16, 2005 | 06:10 PM
cuvner's Avatar
cuvner
i think their standard disk and pads, might not be?! wel i only av standard o.e set up and my brakes are pretty gd, so increasing the dia and having 4pot calipers should see a big inprovement, i should av them in the nxt few days il post up a msg to say how gd they are!!
Old Aug 16, 2005 | 06:36 PM
lutonmike's Avatar
lutonmike
cool if you could do that because i aint gonna oder mine til the end of month.
cheers mate
Old Aug 16, 2005 | 07:11 PM
tonyturbo's Avatar
tonyturbo
4x4 calipers aint 4 pots!
Old Aug 16, 2005 | 07:18 PM
NUTS RuS's Avatar
NUTS RuS
And bigger wheels may be needed depending on size/offsets
Old Aug 16, 2005 | 07:53 PM
cuvner's Avatar
cuvner
Brakes
Front brakes where four pot items on vented disks. Rear braking was also via disks.
just got this info of www.turbocharger.co.uk
Old Aug 22, 2005 | 10:30 PM
cuvner's Avatar
cuvner
fitted my bigbrake kit and bn doing some extensive bedding in last few hrs, wat a difference it has made high speed braking so good just wish i went for grvd disks and performance pads as i only got o.e. ones, nxt on the shopping list!!
Old Aug 22, 2005 | 11:34 PM
Combi_Chris's Avatar
Combi_Chris
ive used wilwood 4 pots , i thought they were great tbh , this was in 97 , when i had a h reg grey turbo, that was quite lively at 220 bhp , but i did have grooved disks also , i would use wilwood again based on the set i had fitted back in the day , right now i have the st brakes, and in all fairness they are a lot better than standard , but still . not the best out there
Old Aug 23, 2005 | 04:33 PM
lutonmike's Avatar
lutonmike
so there pretty impressive the front cossie set up?? have u still got the abs on it?
Old Aug 23, 2005 | 06:11 PM
cuvner's Avatar
cuvner
yea i still got abs on it, really cant be rsd to take drive shafts out n all just too remove the abs! the brakes work so good though! def recommend this set up, cheap big brake setup!!
Old Aug 24, 2005 | 04:49 PM
lutonmike's Avatar
lutonmike
cool mate i think ill be doing the same this month.
Old Aug 24, 2005 | 05:58 PM
Mr.h.'s Avatar
Mr.h.
Im thinkin about doing this brake upgrade, so does everything fit under the standard 15s?
Nick
Old Aug 24, 2005 | 08:57 PM
cuvner's Avatar
cuvner
yea fits under ford 15", the pads are bedding in and my brakes just keep getting better! u actually have better control in the wet cuz u dont hav to press so hard too brake so theres no need to slam ur brakes on and definately can brake alot later!! My toyo proxies are f'n great too, never had tyres which work so well in the wet, no wheel spin at all booting in second and third and wen braking the just bite the tarmac!!
jonfoc
16
Sep 11, 2018 05:35 PM
dombanks
Sep 21, 2015 08:38 PM
Billy_RS
Sep 13, 2015 04:17 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
