Series 2 lowering springs, help needed please!!
Old Aug 14, 2005 | 11:45 AM
RST_mark's Avatar
RST_mark
Default Series 2 lowering springs, help needed please!!
I own a 1990 s2 which is fitted with an unknown make of suspension kit, it's runnning on 17's and at the moment it tends to sit a little lower at the back than it does at the front, i have a small amount of sound equipment in the boot but i think it's because the springs are fairly old. I'm going to purchase a new set of lowering springs this week but i cannot decide which to go for, i was looking for some oppions of what others have had good results with. I don't want to lower the car excessively and would like it to sit slightly lower at the front than at the rear (arch just above the tyre at the front and maybe a cm between arch and tyre at the rear) and a fairly hard spring, at the rear anyway (it's a nightmare trying to get grip down at the moment as it tends to squat a fair bit and lift at the front). I was thinking of something like a 25mm drop from the likes of spax or avo or gmax. Any oppinions and pictures if possibe would be greatly appreciated because nobody can seem to give a straight answer and i want make the right choice.
Thanx, Mark
Old Aug 15, 2005 | 09:06 PM
RST_mark's Avatar
RST_mark
anyone?
Old Aug 15, 2005 | 09:46 PM
antony215's Avatar
antony215
Escort Rs Turbo
ive got 25mm spax on mine alround and it sits fine are you sure the shocks aint fooked on the back
Old Aug 16, 2005 | 05:38 PM
RST_mark's Avatar
RST_mark
yeah pretty sure there ok, they wouldn't determine the height it sits at anyway. Anyone got any pics? of their cars?
Old Aug 17, 2005 | 07:35 AM
mart.rs's Avatar
mart.rs
no your right they wouldnt determine the height,but if they are fooked and you have ice in the boot aswell then that will not help! and they will be fooked,id get a whole new set to really feel the difference,(springs and shox that is)! g-max is reasonably good!
A.t.p
Aug 15, 2015 11:37 AM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
