Modded 4x4 sapphire cosworth for sale
I have my 4x4 sapphire cosworth for sale, spec as follows.
1991 J reg white ford sierra sapphire cosworth 4x4
HPi clear with report
94750 miles
3 owners
some history
ENGINE
PJ MOTORSPORT built 6000 miles ago with receipt
low comp pistons with big valve cutouts (7.5-1 CR)
ported head
bd 14 inlet and exhaust cams
red vernier pulleys
knife edged crank
lightened and balanced crank and flywheel
arp uprated bolts
cometic multilayer head gasket
cometic other engine gaskets
bluesprint chip running 25psi
alcon 6 paddle clutch kit (1000 miles)
grey injectors (1000 miles)
magnecor 8.5mm leads (red)
new dissy cap and rotor
ngk 9 plugs (1000 miles)
2wd exhaust manifold
T34 hybrid turbo with 0.63 housing (2000 miles)
2wd turbo heat shield
3 bar map sensor
radtek rs 500 intercooler
radtek alloy radiator (1000 miles)
samco coolant hoses (red)
sfs boost hoses (red)
roose motorsport ancillary water hoses (red)
chromed rocker cover
bailey turbo damper
chromed amal valve bracket
bailey header tank
bailey mirror image tank
bailey breather tank
red breather fitting kit
alloy power steering tank
pace alloy swirl pot
new thermostat
polished thermostat housing
polished alternator with new diode pack
group A coil (1000 miles)
mongoose stainless exhaust with 4 in tailpipe
poly exhaust mounts
k+n group A spec cone filter and chrome trumpet (300 miles)
BRAKES
bremsport 330mm discs and bells (500 miles)
bremsport 4 pot calipers (500 miles)
new 4x4 rear calipers (500 miles)
drilled and grooved rear discs and pads (500 miles)
braided brake hoses (500 miles)
CHASSIS
fully poly bushed (deflex 500 miles)
gaz coilover shocks and springs (500 miles)
oz super T 17in alloys with good tyres
INTERIOR
full raven leather interior, good condition
white dials
twin pillar pod with clock and lamda gauges
ggr boost, volts and oil pressure gauges in center heater vents
secs monitor
rsoc floor mats
4 spoke rs steering wheel in excellent condition
ecu cover with rs logo
electric windows
central locking
SECURITY
remote piranna alarm
vecta immobilisor
ford immobilisor
handbrake lock
PICS
I have spent in excess of Ł6000 in last few months to get this car to this spec.
I am willing to take part ex on it so WHY??
Any questions or more pics required just ask.
john
94750 miles
3 owners
some history
ENGINE
ported head
red vernier pulleys
knife edged crank
arp uprated bolts
3 bar map sensor
bailey turbo damper
bailey header tank
new thermostat
poly exhaust mounts
BRAKES
CHASSIS
INTERIOR
white dials
secs monitor
rsoc floor mats
electric windows
central locking
SECURITY
vecta immobilisor
ford immobilisor
handbrake lock
PICS
john
if i had some money i would buy another cossie from you and be back with an old friend in the engine bay
PM me a rough price will you please and i`ll have a word with a couple of people
Don't know the car, but can vouch for the motor as it was originally in my saff and built as said 6k ago by PJ to the VERY good spec that it is now and the engine really is sweet as
All the best with the sale
Thanks for the info mate.
Would pm you but this site is unbelievable, I have 2meg broadband and still every page takes about 20 seconds to come up, and I tried to send you 3 pm's at different times but they all seem to remain in my outbox and eventually send!!
Thanks again, may be in touch after my veiwings on friday.
Leigh
Leigh
fancy a deal for a subaru impreza wrx in black mica, 75,000miles, huge folder of recipts
long mot, hks hiper muffler exhaust, hks front pipe, hks manifold,hks blow off valve,
hks induction kit,hks injectors,hks turbo timer,willwood calipers with 330mm disks,
koni suspension,uprated fuel pump,smocked lights and clears all round,gold 17s with
good tires.tracker alarm and clifford concept 300, runs 315bhp at 14psi always run on
optimax. pics at http://photobucket.com/albums/y191/j.../?sc=1&multi=7
from colchester in essex
lukeeboy149
Aug 22, 2015 04:29 PM
