SERIES II OVERHEATING
Old Aug 13, 2005 | 05:15 PM
robbob's Avatar
robbob
Default SERIES II OVERHEATING
Alright, have just had a Rad Tec front mount intercooler fitted but since having it put on the car has been getting really hot - especially when town driving. Got the fan between the intercooler and radiator working correctly, do you think adding another fan to go on the front of the intercooler will make a difference. Or does anybody have any alternative suggestions??? Cheers
Old Aug 13, 2005 | 05:24 PM
Quickie's Avatar
Quickie
I'm running a pair of 10" kenlowe fans on the rad which is behind a very large GRS intercooler and it doesn't seen to give any problems YET!!!
Old Aug 13, 2005 | 06:15 PM
addiction's Avatar
addiction
i also have a pair of 10" kenlowe's and have no problems with overheating. had it on track today and the highest it went to was just above half way
Old Aug 13, 2005 | 06:24 PM
chewyS2RST's Avatar
chewyS2RST
Try emptying the water system and replaceing it with summercoolant,
also fit a seperate fan switch in car so you can have more control over
when the fan cuts in.
You can also try using bonnet raisers to help let the heat out,not everyones
cup of tea i know but ive got a set on mine and to be honest i really dont like
the look but they seem to work. Ive also got thermatec heat wrap around my
manifold,turbo and downpipe
Hope that helps a bit
Old Aug 13, 2005 | 07:13 PM
Stoo's Avatar
Stoo
Hope this doesnt sound cheeky but,...have you got your fans blowing the right way?
My friend runs a RadTec with twin fans and has no problems at all
Old Aug 13, 2005 | 11:55 PM
jezRS's Avatar
jezRS
unfortunately i fitted a new fan to mine and wired it up the wrong way so it spun the wrong way, therefore not helping matters at all and makin it hot.
easy mistake to make
Old Aug 14, 2005 | 11:23 AM
GrimmeRS2K's Avatar
GrimmeRS2K
as said, would deffo fit 2 kenlowes, makes a huge difference, also a good rad helps
Old Aug 14, 2005 | 09:17 PM
robbob's Avatar
robbob
Changed the wires around on the fan, but when the car has warmed up it only seems to blow hot air around - no cooler?? Have a Pro Alloy radiator, bonnet raisers, flushed the radiator out and addedmore coolant. Don't suppose anybody has any other sugestions.
Old Aug 14, 2005 | 09:40 PM
p.kay4's Avatar
p.kay4
I KNOW IT MIGHT SOUND CRAZY BUT HAVING THE CORRECT % COOLANT MIXTUE CAN MAKE THAT DIFFERENCE
Old Aug 14, 2005 | 09:42 PM
AJC's Avatar
AJC
i have no probs, fan kicks in at half way and it never goes above there
Old Aug 15, 2005 | 12:20 AM
RSTEVE's Avatar
RSTEVE
[quote="Stoo"]Hope this doesnt sound cheeky but,...have you got your fans blowing the right way?
had problems with mine overheating since i put a control for the fan on a switch now i know why !!
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
