cosworth turbo's???
Old Aug 12, 2005 | 05:44 PM
RS Dan's Avatar
RS Dan
Default cosworth turbo's???
Hey guys, fairly new to all this, so could really do with your help!!!..
Just a quick question then, are all the turbo fitting's/housings the same throughout the cosworth range? Just spotted a couple of t34's for sale:
And also how hard is it to fit -and get running proper- a t34 turbo?
(car currently is running t3, dark green's, pectel ecu, 3abr map, -31 etc)
thanks in advance
Old Aug 12, 2005 | 08:12 PM
daz1968's Avatar
daz1968
would need remapping to suit turbo, but only 2 fitments on std cossie 2wd and 4wd, but to get round this only housings need turning on turbo, and I think one has studs on manifold joint and the other bolts, but can be worked round.
Old Aug 13, 2005 | 09:03 AM
wimwerf's Avatar
wimwerf
yep...need another chip change.....for what car is it...?
maybe you could introduce yourself.....because your new here...
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
