3Dr Cossie speedo?
I have a wee problem with my 3 Dr's speedo! it seems to run between 5 and 10 mph lower than I am actually going!! Has anyone ever had this before and If so what was the problem??
Thanks
Nick
Thanks
Nick
maybe you have bigger diameter wheels, than original one? that changes your overall ratio. you need the replace the speedometer cables pinion to one that have correct ratio to your vehicle and then fine tune it.
Yeah Have already thought about that as well but nothing to do with the wheels!! maybe have the wrong speedo drive cable on it!
Does anyone have a 3 door speedo drive cable???
Russ Payne
Sep 25, 2015 08:29 PM
