Clutch slipping only sometimes!
The clutch slips but only sometimes! When it is hot it doesnt do it unless I launch it! then sometimes it will be fine! If it was fooked wouldnt it just slip all the time?
Mine was the same and it wasn't the clutch that was the problem but the release bareing. Drive normally and it was fine, but launch it, clutch slipped big time.
old one on top and the new one under, as that was fooked it did this to the clutch plate cover.
Then the clutch wouldn't release at all.
mines is slghty the same but has a new paddle clutch in it, found out it was the crankshaft seal leaking oil onto the clutch after a long drive. i didnt beleive this but you could see oil seeping down the block into the box! only for a couple off quid on seal!!! i was think the new clutch had gone after 800 mile!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
check what grimmeRST said first before changing the clutch as it might be just the rachet or cable
