WILL AIR-CON FIT ONTO A 1990 SAPP COSWORTH
Would the air con system (loom switchs pipes pump condenser etc..) out of a 1992 spec sapp go straight in to a 1990 sapp or is there more work to do rather then simpley plug it all together???
Originally Posted by Spiky
isn't the shell different behind the stereo???? to mount something?????
buldge in the bulkhead???
the bulkheads different on the latespec sapphires to allow for the ford aircon, i suppose you could bash it in a bit to make room, plus late spec (green top engines) are all polly v, cheers nomad
The aircon bulkead has a box about 15" wide, 4" high and 4" deep for the larger airbox to slot into in the engine bay.
If the dash and everything else is out it isn't hard to do, it is just a big box you need to fabricate - or do like me and cut it out of the donor.
Originally Posted by Rhys
I asked this a while ago DOO have a search!!! come to the conclusion was to much work!!! so im still on 1980 air con! put window down
if you've ever had proper working air con in hot weather for any distance (and know how to use it properly), you'll never want to be without it again.
air con systems contain gas under pressure - be careful when working on them. it's not too difficult to take a complete system from a sierra fitted with factory fit air con and fit most of it to one that wasn't. as has been said before, the bulkhead is different to make space for the evaporator and air recirculation system. the wiring is a bit tricky, and you must have all protection devices working. and additional large electric fan as factory fitted or better will be required on the front of the condensor. that fan will be one of the biggest users of electrical power on the whole car, so make sure that you've got an alternator and wiring that is up to it.
my mk1 escort has air con, necessary cos i fitted fixed polycarbonate windows for light weight - the weight of the a/c system was way more than what i saved by loosing the glass and the mechanisms, but it was worth it for the proper cooling you get in the summer.
COSWORLD
Aug 14, 2015 07:40 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
