2wd cossie rear diff in to a 4x4
Old Aug 8, 2005 | 09:09 AM
jim jones's Avatar
jim jones
Default 2wd cossie rear diff in to a 4x4
Does anyone know if a cossie 2wd rear diff will be ok in a Escort 4x4 set up running about 500bhp. I know I will need the whole back end half shafts etc. but will it stand the power or do I need a bigger rear diff, if so what should I be looking for.
Old Aug 13, 2005 | 06:19 PM
2ndGear's Avatar
2ndGear
the bearings and everything else in the diff are the same weather 2 or 4 wd. You will be best with a bigger diff
Old Aug 14, 2005 | 02:02 PM
the original's Avatar
the original
thought it's a different ratio to the front and would ruin your centre bearing?
Old Aug 14, 2005 | 04:19 PM
markk's Avatar
markk
the swap is easy , will it last ? ............. if you use the fullpower to its max extent - no it wont last at all
hth
Oct 9, 2015 07:38 PM
FlashRS
Sep 14, 2015 12:36 PM
rog
Aug 30, 2015 05:32 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Old ford
Jul 31, 2015 06:50 AM
