Baileys Breather
Old Aug 7, 2005 | 04:26 PM
Trev's Avatar
Trev
Default Baileys Breather
Can anyone let me know what i need to fit the above? also which pipes go where?
I am sure there was a post on this a while ago but I can 't find
Thanks
Trev
Old Aug 9, 2005 | 05:19 PM
Trev's Avatar
Trev
c'mon peeps
Help
Old Aug 9, 2005 | 06:41 PM
Stoo's Avatar
Stoo
Do you have the fitting kit?
If so i can help you!
Old Aug 9, 2005 | 08:04 PM
1.9s1's Avatar
1.9s1
This may help mate
1 of top pipes goes to far side of rocker cover, other to near side, bottom ones, 1 return to block / sump other to metering unit.
Old Aug 9, 2005 | 09:12 PM
Trev's Avatar
Trev
that helps a bit - what about the two pipes underneath?
No don't have the fitting kit - was going to get some pipe and put together anyone know what size I need?
Old Aug 9, 2005 | 09:13 PM
Trev's Avatar
Trev
woops just read the bit at the bottom !!!
Nov 1, 2015 06:53 PM
155lee
Oct 27, 2015 04:55 AM
