plugs and gaps running 2 bar
Old Aug 7, 2005 | 04:20 PM
gibbo frst's Avatar
gibbo frst
Default plugs and gaps running 2 bar
used c57 on my old standard engine running stage 3 so brought a set for my new low comp engine was running ok on boost for few hours but now splutters on higher boost.. had this prob when went to stage 3 and was told to make the haps smaller... any ideas please... ta
Old Aug 7, 2005 | 04:23 PM
Stu @ M Developments's Avatar
PassionFords Creator
Erm.... make the gaps smaller
Old Aug 7, 2005 | 04:33 PM
gibbo frst's Avatar
gibbo frst
do you have a figure in mind at all.. they were 0.7 mm so i was gonna try 0.6.. is this too much or little?
Old Aug 7, 2005 | 04:46 PM
0.65 is an average figure for a car running 24psi on std head.
Old Aug 7, 2005 | 04:56 PM
gibbo frst's Avatar
gibbo frst
ok cheers mate... its an a1 rallysport engine with group a head and bd14 inlet and bd10 exh 7.2 :1 comp.. they said the ecu is a group a spec i have read about your closed loop lambda conversions would the ecu be compatible for one of these.. its a L8 in a 2wd.. just realised how much more fuel its used on the greys from greens on my old engine.
Old Aug 8, 2005 | 09:05 AM
b14dave's Avatar
b14dave
if using around 25 p.s.i set the gap to 25thou that will stop the spark being blown out when boosting.
Old Aug 8, 2005 | 10:07 AM
gibbo frst's Avatar
gibbo frst
ok whats this in mm... many thanks
Old Aug 8, 2005 | 11:49 AM
july1's Avatar
july1
In the GpN manual they talk about 0.5mm
Old Aug 8, 2005 | 12:56 PM
gibbo frst's Avatar
gibbo frst
ok nice one.. ive gone feom .75 to .6 and it seems ok so far so ill see how i get on.. cheers
Old Aug 8, 2005 | 01:50 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
My motor dont like c57s, same as yours after a very short time starts to missfire on boost.
Now use PP8s and had no probs
Steve.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Neatrags
Aug 16, 2015 07:57 PM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
