General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Its fairly easy to do mate. you will need: efi loom, fiesta rst ecu & map sensor, edis mod, coil pack, efi manifold, trickiest bit is sorting out crank possition sensor i did mine with a fiesta rst one as i already had the hole in my block for it but i believe it can be done with a sierra 1800 bottom pully set up which will save having to change the flywheel.
no probs, yes you'd be running efi injectors, either fiesta rst blue injectors for upto i think 180 bhp or biege for upto 220 bhp or bigger again for big horse power.
