RS Turbo Radiator dimensions
I have a peugeot 205 gti with a turbo conversion and its running a bit hot, I think this is due to the standard radiator being too small
I've got a 1.6 orion radiator on at the moment which is the same size as the 205 gti radiator
I thought that with the rs turbo being a turbo, the radiator will be able to handle turbo tempratures!
Only problem is I dont know the size of an rs turbo rad!
Could anybody maybe measure their radiator and tell me what size it is so I dont end up buying something that doesnt fit! (also if you could measure it including the intercooler that would be a great help!)
Much appriciated
Rob
Much appriciated
Rob
Rob the S2 radiator is 560 x 330 x 40 I believe that the S1 rad is 150mm longer but slightly less that the 330height of the S2 one.
Bear in mind that the original incercooler sits alongside the radiator on turbo charged models, hence the reduced size.
Adam Graham
Sep 6, 2015 06:04 AM
