HELP!!!!!!!!!
Old Aug 5, 2005 | 07:55 AM
Franco's Avatar
Franco
Default HELP!!!!!!!!!
Right the escorts going to Harveys on Monday morning & it seems like the water pumps playing silly bollocks
I'm loosing Max to Min on average every couple of days, and everytime we get her on the ramps the leak seems to vanish! DOUBLE
Is it a hard job to change the pump & where's the best place to get one....Might as well buy a new one i suppose.
Jason
Old Aug 5, 2005 | 09:07 AM
Damo V's Avatar
Damo V
You defo sure the pump and nopt H/G?? Are you checking water level at cold? have you done a block test?
Damo V's Avatar
Damo V
Though I should add, dead easy to change water pump, I personally would just buy new
Old Aug 5, 2005 | 09:12 AM
Franco's Avatar
Franco
Oh fook..........Never thought of that
Think i'll ask Harvey to do a H/G test........
Cheers Damo.
Old Aug 5, 2005 | 09:14 AM
Damo V's Avatar
Damo V
LOL, can tell you aint owned a cossie for long
Obviously a block test isnt a surefire way of confirming you dont have a HG blown, but it could give you an indication if you do
Good luck....
Old Aug 5, 2005 | 09:23 AM
Franco's Avatar
Franco
Well it seems to be seeping from the front of the block while it was on the floor, but as i say by the time we got her up on the ramps the leak had stopped
Mate said it looked like it was coming from the pump..........
Also i drove Ldn to Manchester this week, on the way up there she never lost a drop of water
God knows
Old Aug 5, 2005 | 09:27 AM
Damo V's Avatar
Damo V
About right... only loosing water ON BOOST .. common place is the side of block below exhaust manifold, have a look, if the block is clean, it will be stained with the antifreeze,
As said always check water when cold
When I blew my HG it only dripped out once stopped driving, but couldnt see leak block test comfirmed it though
Old Aug 5, 2005 | 09:29 AM
Franco's Avatar
Franco
Damo,
Would i not get oil mixing in with tthe water etc?? These seem fine....
Old Aug 5, 2005 | 09:32 AM
Damo V's Avatar
Damo V
Not necessarily, the compressed gasses simply blow across block face into waterway
Old Aug 5, 2005 | 09:35 AM
Allegedly running not enough antifreeze (antcorrosion too) can increase the chances of it failing on a waterway, never really tested the theory though.
Old Aug 5, 2005 | 09:37 AM
Franco's Avatar
Franco
Whatever way i look at it....................
I could be fooked this month!
Damo V's Avatar
Damo V
You could try taking cap off after a bit of a run, see if can smell H/C.. though I personally have never found this to be effective, cant smell shit, after all the paint ive ingested
Old Aug 5, 2005 | 09:39 AM
Change the water pump, its good maintainance anyway, i did it as soon as i bought mine even though there were no problems (make sure you go for a decent spec pump not a crappy aftermarket one), then see if the problem persists.
Old Aug 5, 2005 | 09:49 AM
Franco's Avatar
Franco
Yeah i'm going to whatever the weather chip!! Won't hurt!
Old Aug 9, 2005 | 10:07 AM
Franco's Avatar
Franco
Little update for you.......
The head gasket was failing & she's now sitting up at Harveys workshop getting sorted.
Hopefully it'll all be good after this!!
Old Aug 9, 2005 | 09:12 PM
Damo V's Avatar
Damo V
How was it comfirmed mate?
What gasket you going for?
Old Aug 10, 2005 | 07:50 AM
Franco's Avatar
Franco
Damien,
I went up to Harveys on Monday morning for my big wing sump & he checked it by putting the emissions tester in the header tank.
It was on its way out, hadn't completely gone but because it was up there thought it best to get it done before any real damage was done!!
Think its a Group A one going on there............
Old Aug 10, 2005 | 08:17 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Jase,
Why do you only "think", I told you yesterday it was for definite .
Did your carbon arrive okay?
Old Aug 10, 2005 | 08:24 AM
Damo V's Avatar
Damo V
nowty wrong with grp a, save the expensive ones for the engine rebuild
Old Aug 10, 2005 | 08:25 AM
Franco's Avatar
Franco
Oh shut up Michael!!
Yes it IS A GROUP A HEADGASKET..................Just for Mike!
The surround never turned up yesterday Mike, no one was in until 2ish though....
Looked for a delivery note etc, so hopefully it'll be today!
Another WHINGER off your back then!!!
Old Aug 10, 2005 | 08:30 AM
Franco's Avatar
Franco
Damien..........
She'd be scrapped if i needed a new engine, the missus would have kittens then a baby if i told her how much a rebuild would cost!!
PS Mike are you on commission from SCS
Old Aug 10, 2005 | 08:33 AM
Mike Rainbird
Caraholic
Jase,
I wish, I even have to make the tea when I'm there .
Old Aug 10, 2005 | 08:35 AM
Franco's Avatar
Franco
Make sure your there Friday afternoon then...................
White, one sugar( not sweet enough yet!!)
