Abs
Old Aug 3, 2005 | 01:18 PM
JamesS2RS's Avatar
JamesS2RS
Default Abs
How do u remove the abs??
Old Aug 3, 2005 | 03:01 PM
mart.rs's Avatar
mart.rs
do you want to just remove the belt or the whole piping system?
Old Aug 3, 2005 | 03:19 PM
JamesS2RS's Avatar
JamesS2RS
Well people have said i need to remove my abs before i upgrade my brakes E.g. Rear disk conversion and bigger front calipers... what do they mean?? and what do i have to do??
Old Aug 3, 2005 | 03:26 PM
mart.rs's Avatar
mart.rs
no you dont need to move it just to fit new front calipers or discs and pads,if your doing a rear conversion then obviously you would need to remove the pipes etc....,which if you do decide too remove the lot then get hold of an xr3i master cylinder because it doesnt have the pipe holders that come out the side of it that go to the abs system!
Old Aug 3, 2005 | 04:00 PM
JamesS2RS's Avatar
JamesS2RS
Can u run the abs with a rear disc conversion?
Old Aug 3, 2005 | 04:05 PM
mart.rs's Avatar
mart.rs
im not sure mate,i can find out for you if you like will be back on tomorrow around 830 am ill pm you ok
Old Aug 3, 2005 | 06:21 PM
adamS2RST's Avatar
adamS2RST
Yes you can but the abs system on the s2 is shite imo!
I got mine removed Gadget off here done it, top man
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
