Saph 2wd buying
Old Aug 2, 2005 | 12:23 PM
SamERST's Avatar
SamERST
Default Saph 2wd buying
Can anyone give me any info, im hoping to swap my erst for a grey 88 2wd saph.
Also what will be quicker ?
My erst spec:
Stage 2 1600 cvh engine with ported + polished head
Stage 3 Hybrid T3/T4 turbo
-31 Actuator
Ahmed bayjoo fully mapable chipped ecu (currently peeking at 1.5bar and flatting out at 1)
Full Mongoose stainless steel exhaust system with 3" outwardly rolled tailpipe
Polished bailey dump valve
Under bonnet bleed valve
Cossie spec:
Stage1 Chip giving 285 BHP.
Group A Head Gasket.
Group A Dump Valve
What sort of 0-60 and 1/4 mile times would the cossie do ?
Sam
Old Aug 3, 2005 | 01:58 AM
cossiedaz's Avatar
cossiedaz
depends on setup and launch technique and the driver, possibly a low 14second run. best i did at pod was a 14.3@105mph running about 340bhp,about a year and half ago, however i had a slipping clutch knackered box and blown headgasket.
2wds arnt the best for pod as they have long gear ratios
low profiles tyres dont do favours either
all depends on the setup and launch technique
Old Aug 3, 2005 | 01:20 PM
SamERST's Avatar
SamERST
Cheers mate, so down the pod what would be quicker the coz or the rs ?
by the way i can launch rwd cars pretty good
Old Aug 3, 2005 | 09:10 PM
cossiedaz's Avatar
cossiedaz
hard to say mate, if the rs is close to 200bhp it will be very close, cossie will have a higher terminal though in my experience.
Old Aug 4, 2005 | 08:29 PM
rabmc's Avatar
rabmc
Will have to favour the cos if its a real 285 bhp and well set up it WILL do the rs IMO
Old Aug 16, 2005 | 04:38 PM
cozzie4d's Avatar
cozzie4d
I say cos 2wd too. Mostly when a seller says 280bhp it means a stage1 chip and no more. Which unfortunately mostly means around 255 or 260bhp
But since I own a cos; go for the cos 2wd
slammedorion
15
Nov 1, 2015 07:17 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Ben26
Sep 3, 2015 07:55 PM
FlashRS
13
Aug 31, 2015 06:02 PM
