s2 rst Pinking on high revs
Old Aug 1, 2005 | 05:17 PM
AKRS1's Avatar
AKRS1
Default s2 rst Pinking on high revs
pinks at about 5k anyone knows what that means. overfuelling or running too much boost? its not the octane as im using super unleaded
Old Aug 1, 2005 | 07:17 PM
JamboRS's Avatar
JamboRS
focus rs 1672
running lean,prob runnin to much boost and only a matter of time before its fatal
Old Aug 1, 2005 | 08:51 PM
GrimmeRS2K's Avatar
GrimmeRS2K
could be the ignition timing slightly out, or as said maybe a bit lean top end
Old Aug 1, 2005 | 10:21 PM
addiction's Avatar
addiction
sounds like a bit of detonation to me!!! not good
Old Aug 2, 2005 | 11:55 AM
Oranoco's Avatar
Oranoco
Get it in to a tuner and setup asap or it could end in very expensive tears.
Mind you, you too could have a paperweight like mine
Old Aug 2, 2005 | 04:05 PM
mart.rs's Avatar
mart.rs
definitly detting mate,i agree get it in to a tuner a.s.a.p!
Old Aug 2, 2005 | 05:57 PM
AKRS1's Avatar
AKRS1
turned down now to 12psi and seems fine. To be honest i was doing 120 when it started pinking maybe it overboosted or something but seems okay now. But still probably get it checked out thanks people
Old Aug 2, 2005 | 11:21 PM
Manchester Mike's Avatar
Manchester Mike
Its detting mate, deffo get it checked out, i had same problem.... then this happened....
Not a good look
Old Aug 3, 2005 | 07:58 AM
mart.rs's Avatar
mart.rs
what petrol are you using?optimax?
Old Aug 3, 2005 | 04:53 PM
AKRS1's Avatar
AKRS1
normal super unleaded
Old Aug 3, 2005 | 10:24 PM
addiction's Avatar
addiction
it was definately detting dude!!!! you really should get it set up properly by a tuner or it WILL go bang
Old Aug 4, 2005 | 09:35 AM
jezRS's Avatar
jezRS
i agree get it looked at, last summer i was holding my RS flat out home from chelmsford (roughly 90 miles) and wen i got back all i could hear was a loud banging noise, melted a piston and piston ring.
wouldnt have minded but id only had it rebuilt about 2500 miles before hand
if it does need a rebuild do the ZVH conversion, it fuckin rocks
Old Aug 5, 2005 | 07:58 AM
mart.rs's Avatar
mart.rs
So your using optimax then yeah?
Old Aug 5, 2005 | 09:05 AM
AKRS1's Avatar
AKRS1
waiting for the tank to go on near empty then i will fill it with optimax at 95p a litre
A.t.p
Oct 23, 2015 07:54 PM
A.t.p
Sep 29, 2015 05:04 PM
