some rebuild pics/(update, on wheels)
Old Jul 31, 2005 | 11:08 AM
righthooker's Avatar
righthooker
Default some rebuild pics/(update, on wheels)
Shell in paint shop
needs flating and polish to be done when together as it will no doubt get marked during rebuild.
loomb back in
used a saff dash as mine was shocking and we all know how difficult it is to get a 3 door one
underside painted in ford grey(looks very white in the pics)
rear assembly back in almost
freshly skimmed fly wheel,ap 4 paddle and heavy duty plate and bearing .
Hopeing to have it all back together for national day,credit has to go to my mate Karl (king of bling)as i just hold spanners and the wallet.
Still a lot to do but living in hope
Old Jul 31, 2005 | 11:11 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Are you going for concourse?
Looking good tho mate
I remember a Thread from you before, wasnt your old shell rotton??
jacko's Avatar
jacko
looking nice mate is it going to be ready for national day
Old Jul 31, 2005 | 11:12 AM
Niall.b's Avatar
Niall.b
looks very well. good luck with it
Old Jul 31, 2005 | 11:16 AM
righthooker
absoloutly not mate ,would rather be smacked accross my bell end with nettles
Just want it to be nice and clean and useable
absoloutly shafted mate
Karl recons about a fortnight mate so it has a slight chance of showing up at the next meet mate on the 14th
Graceland's Avatar
Graceland
Team HOTHOT!
not been funny - but the skimmed flywheel will be eaten by the padel clutch its much better to pay extra and have them surface ground instead as they will last then
Old Jul 31, 2005 | 11:19 AM
Graceland's Avatar
Graceland
Team HOTHOT!
and yeah - your car is stunning
jacko's Avatar
jacko
clive knows all about been hit on the bell end with nettles dont you mate
Old Jul 31, 2005 | 11:21 AM
Charlie Chalk
Unknown.
PMSL, Good Good
I thought so , shame but glad to see this coming on
Old Jul 31, 2005 | 11:26 AM
righthooker
Got sme parts last night of a lad near newcastle ,who was busting his because he couldnt afford to rebuild his engine .Real shame as it was not a bad car,.
If i had of bust mine i could have used that, and the money i have now spent on another one .Though it is so difficult to get an honest car ,i thought i would take this route.
Old Jul 31, 2005 | 11:28 AM
righthooker
Gracy,never heard of surface ground but am allways open to advice .Where would this be done (machine shop ?)what is the procces
Old Jul 31, 2005 | 11:32 AM
righthooker
thought it would be moved eventualy
just you dont get as much reaction here
no prob
Old Jul 31, 2005 | 11:35 AM
Graceland's Avatar
Graceland
Team HOTHOT!
its done in a machine shop aye.
all they do is put your flywheel onto a big magnetic table that moves left to right and has a fixed grinding wheel above it.
they raise the table untill the grinding wheel touches the flywheel and then start the movement forwards and backwards.
while its doing this, the table also moves fore or aft to grind the whole surface leaving it mirror finish and super flat.
costs about 20 to 30 quid more and can be done in any good machine shop, and the best thing about grinding is it removes LESS material than skimming - skimming can remove about .5mm, whereas grinding will only be about .2mm
Old Jul 31, 2005 | 11:37 AM
Graceland's Avatar
Graceland
Team HOTHOT!
and if i was still working at Holset engineering, i'd be doing all my own machining and the like
Old Jul 31, 2005 | 11:40 AM
righthooker
Cheers for that explanation mate
Old Jul 31, 2005 | 02:18 PM
plynchy's Avatar
plynchy
Looking well bling mate Won't stay that clean underneath for long i reckon,good work Karl and Clive for keeping out of the way
Old Jul 31, 2005 | 02:34 PM
B11GNS's Avatar
B11GNS
I noticed that the picture of the flywheel had 2 sheared dowels, were these replaced before it went back together? i ask because i had a problem when i left 1 dowel sheared and put it all back together eventually it started vibrating at a certain rpm and when i took it all apart the flywheel and cover plate was burnt at the point where the dowel was missing
Old Jul 31, 2005 | 08:09 PM
righthooker
2 sheared dowels
never gave it a thought to be honest,will have a word about it with my garage slave
Old Jul 31, 2005 | 09:24 PM
Old Aug 1, 2005 | 10:00 AM
jacko's Avatar
jacko
hope you have a lot of old tooth brushes for cleaning that floor
Old Aug 1, 2005 | 08:27 PM
righthooker
no
Old Aug 2, 2005 | 07:37 PM
righthooker
so rear is all in and the front about done ,new fuel and brake lines ,.
engine and box to be put back in and running for the weekend.
still lots to do will do some more pics end of the week
Old Aug 4, 2005 | 02:19 AM
robrs2's Avatar
robrs2
Just found this post (yes i'm slow ) Looking good Clive I take it you'll be Mr show'N'shine for next year
I'll be over for the bushes M8
Old Aug 4, 2005 | 07:42 AM
rs nuts's Avatar
rs nuts
fair play too you m8 when you was selling it you changed your mind and said you was going too doo it up and sure enough you are top job
Old Aug 5, 2005 | 02:09 PM
cozzie4d's Avatar
cozzie4d
Great job you're doing there. Taking care of the underside and all..
Perfect
Old Aug 5, 2005 | 05:26 PM
jacko's Avatar
jacko
cant wait till its done another 3door in the convoy to natianal day its going to look mint with those wheels you have got. have you done out with the motor while its out
Old Aug 6, 2005 | 08:05 AM
righthooker
So got the engine and box ,propshaft and the front suspension ect in ,.
so time for a few pics
was hopeing to get it running this weekend but not going to happen as i need to get the turbo ,and get the zorst made up
Old Aug 6, 2005 | 09:06 PM
righthooker
No ,no need realy.
Just changed the turbo for a T34,and sorted a straight through side exhaust.Also got a decent breather done.
Should just be a better stage 3.
Could have done cams i suppose,but didnt want to mess around with something that has been good for the last 2 years
Old Aug 6, 2005 | 11:05 PM
plynchy's Avatar
plynchy
Side exit exhaust?? I guess you're not bothering putting the stereo back in then?
Old Aug 7, 2005 | 02:02 PM
righthooker
a loud one mate ,zorst has no boxes on it
may neeed to re think when we start it up
Old Aug 7, 2005 | 02:42 PM
jacko's Avatar
jacko
fuck it wear ear plugs and anoy the naighbours
Old Aug 11, 2005 | 09:44 PM
righthooker
re think needed ,i know its in the garage but fuck its loud
Old Oct 5, 2005 | 08:01 PM
righthooker
been done a while ,got it done night befor nat day
hope you like it ,stripes to come on the sides and it is coming back up to standard ride height on uprated springs,and a new zorst as i have lost the art of conversation
Old Oct 12, 2005 | 10:30 PM
JeffJ's Avatar
JeffJ
Now that is one NICEEEEEEEEE cossie!! stylin is quality mate wot rims r they ?? n do u av n e pics of the rear i like the rear lights
Old Oct 12, 2005 | 10:54 PM
Red16's Avatar
Red16
looks hard as nails
Old Oct 13, 2005 | 08:21 PM
tracktoy's Avatar
tracktoy
nice work
Old Oct 13, 2005 | 09:24 PM
righthooker
thanks for the kind words
Rims are" Allu star type Q" got em in germany about 4 years ago but had em painted and pollished a couple of months ago 50quid per rim
Old Oct 13, 2005 | 09:59 PM
cossiedevil's Avatar
cossiedevil
Great job you've done on it
Old Oct 13, 2005 | 11:04 PM
Benni's Avatar
Benni
Ban[B][/B]ned
Very nice mate....Looks really mean lol
Old Oct 13, 2005 | 11:45 PM
Zetecfiesta's Avatar
Zetecfiesta
looks absolutly stunning!
