2WD Race or Track suspension setup ..Pics added..
Here is a complete front setup for race or trackday 2wd cossie,
Bilstien Front coilovers, [part no, 55396 500 200 ]fitted with springs, [part no, 7p 650 s ]**SOLD**
Alloy spherical top mounts,**SOLD**
Sitting on Sapphire front hubs,
In-situ adjustable TCA,s with rose jionted inner jionts,
Compression Struts, in -situ adjustable, bolt on brackets,**SOLD**
Seperate Alloy front crossmember to carry "blade" type anti-roll bar,
[bolts up thro chassis legs in front of std crossmember]
Comes complete with anti-roll bar, with blades,[part no 9092232] and drop links that fix to ends of the compression struts.**SOLD**
Also, Bilstien Mag rear coilovers complete, [part no 9095163] rose jionted top and bottom, they have helper springs, do not know spring rate for these! £200.
Avaliable soon, 2WD Group A rear beam, with adjustable rear arms , steel[big rose jionts on both pivot pionts ],with std rear discs and calipers, pollybused beam mounts. £400.
Thanks for looking
Thanks for looking
JPA
Nov 8, 2015 12:26 PM
Nov 3, 2015 04:08 PM
FlashRS
13
Aug 31, 2015 06:02 PM
