Running on 3 cyldner's when ticking over Help?
Old Jul 30, 2005 | 11:37 PM
johnnymac's Avatar
johnnymac
Default Running on 3 cyldner's when ticking over Help?
When my 3 door cossie is ticking over,it's misfiring on back cyldner.but when driven is running fine,tried leads and plugs but still the same.if there is anyone out there with answers to this please get on to me.
My email is johnnymac2@hotmail.com
Anyhelp would be very appericative.
Thanks John
Old Aug 4, 2005 | 07:01 PM
vyper developments's Avatar
vyper developments
Hi Mate,
if you are sure the plugs and leads are ok then it could be an air leak into the manifold, test this by spraying a sniff of easy start around the intake manifold, if the engine picks up then a new gasket is needed.
If this does'nt work then you could possibly have an injector (not delivering enough fuel on tickover) or a wiring problem. The other possibility is that you could be losing compression so best carry out a compression check and see what the readings are across 4 cylinders.
Hope this helps!
Regards, Mike.
Old Aug 5, 2005 | 10:33 PM
Ian M's Avatar
Ian M
could be the head gasket letting water in on idle, then as the revs rise the cylinder pressure keeps the water out. i have had this in the past.
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
dojj
Sep 8, 2015 08:31 AM
