HELP NEEDED:-{
Old Jul 29, 2005 | 03:17 PM
cressy's Avatar
cressy
Default HELP NEEDED:-{
IS THERE A SPECIAL TOOL TO GET THE NUT OFF THAT HOLDS THE PULLEY INTO THE ALTENATOR ON A COSSIE CHEERS
Old Jul 29, 2005 | 05:22 PM
Matt's Avatar
Matt
do you mean where the long bolt goes through at the base? the bushes that press in when you tighten it up refused to budge on mine, i ended up taking the whole mounting off the block itself and then bashing them apart
Old Jul 29, 2005 | 08:40 PM
cressy's Avatar
cressy
done it now matt thanks only took me six and half hours just hope that sorted the problem
Rippers
107
May 28, 2005 10:39 AM
