advice/experince bout high bhp rst
Old Jul 24, 2005 | 10:43 AM
RS-adam's Avatar
RS-adam
Default advice/experince bout high bhp rst
Hi mates... got a question bout a 5 th injecter set up....
I have a S2 wit a 1900cc, uprated head, a cv37 and T3 trim 60, and I would like get just above the 250bhp mark..., I running low boost at the moment... but, I would like to end up driving wit about 1,5bar... (dont know how many psi that is)
I talked with a danish tuner... and he adviced me to ditch the 5.th injecter, and have my std inlet manifold modified to fit 4 extra injecter.. and have them controlled by my Mf2..
his reason for doing this, was that he said, wit a 5 th injecter that sits before your throttle body, you cant control if every cylinder gets the same amount of fuel
what do you think of this idea...??
Old Jul 24, 2005 | 11:10 AM
Stoo's Avatar
Stoo
RS-adam,
About 21psi mate
Old Jul 24, 2005 | 11:21 AM
RS-adam's Avatar
RS-adam
tanx mate... do you have any advice bout my little "problem"
I know paople are using the 5.th injecter for high BHP cars.. thats why I wawe couriuos
Old Jul 24, 2005 | 12:13 PM
wildheart's Avatar
wildheart
Know of several big Bhp rst's running the Erl/Mf2 5th injector setup.
As far as im aware as long as you have the correct injector/mapping then its fine
Old Jul 24, 2005 | 12:18 PM
Stoo's Avatar
Stoo
Umm not sure,i was having a think.Alot of people use the 5th injector so it's tried and tested without any problems and gets good results.As for fitting another 4 injectors,i highly doubt the standard ERST fueling could cope with that,id imagine its alot of money to get done right while a 5th injector setup will prob only cost £250-£300
Old Jul 24, 2005 | 02:52 PM
RS-adam's Avatar
RS-adam
thats was also my thought.. many use the 5th injecter without problems...
the std ERST produces about 5-6 bar of fuel pressure... so the danish tuner I talked to, meant that there would be no problems wit fittin 4 exstra injecters... the plan was, so split the fuel line up in 2, just before the fuel distributer, and run the second fuel line up to at fuel brigde (or whats its called), and the feed the 4 injecter from there..
This is still just something im running thrugh my head.. thats why I wanted some feedback from the board
Old Jul 27, 2005 | 09:26 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I used the standard 4 injectors with a modified metering unit to run 24psi held and 220bhp @ Wheels. Fueling was spot on, although it was very juicy when cruising along the motorway but no problem with a lack of fuel at the top end.
Old Jul 28, 2005 | 07:20 AM
JesseT's Avatar
JesseT
Wouldn't it be much less hassle to just use an EFI inlet manifold.
Old Jul 28, 2005 | 07:55 AM
RS-adam's Avatar
RS-adam
jesseT: you mean to just put efi on it, insted of mfi?
Old Jul 28, 2005 | 08:23 AM
JesseT's Avatar
JesseT
Exactly. And no I don't mean a Ford EEC-IV efi! I'm not really a big fan of OE management conversions.
Old Jul 29, 2005 | 01:34 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Mine ran MFi and NO 5th Injector at 250bhp. Infact I have never run a 5th Injector on my car. I went straight from a Standard Configuration 4 Injector MFi Setup to EFi.
In answer to your question, I would keep with the 5th Injector as it is. It is quite crude, but at least it allows for sensible off-boost and low boost fuelling with increased enrichment higher up.
Old Jul 29, 2005 | 03:27 PM
mart.rs's Avatar
mart.rs
id go for the efi set up as its easily mappable and more drivable than fart arsing around with the standard management
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
A.t.p
Sep 29, 2015 05:04 PM
