what oil to use when running in?
Old Jul 22, 2005 | 07:12 PM
chewyS2RST's Avatar
chewyS2RST
Default what oil to use when running in?
Engine should be up and this weekend so what oil should i use
to run my engine in ?
I.E make and grade
Old Jul 22, 2005 | 08:17 PM
Rallyesport's Avatar
Rallyesport
If you have changed your piston rings, use ONLY mineral oil for the first 1500 miles of street running. 10w-40 is a good choice. Change your oil and filter after 20 miles, there will be much debris. Do hard runs for the first hour of running the engine, just warm it up first. If you have not touched your bores of rings, mineral oil or hard runs are not needed.
Old Jul 22, 2005 | 09:38 PM
richard_xr2i1800's Avatar
richard_xr2i1800
what do u mean by hard runs
Rich
Old Jul 22, 2005 | 09:46 PM
Rallyesport
Empty 2. and 3. gear, then brake and do it again. Well up to 5k RPM should be enough.
Old Jul 22, 2005 | 09:51 PM
swerv's Avatar
swerv
i think we all have different ways off running in , just use mineral oil and common sense for the first 1k
i would not put the engine under hard load for the 1st hour of running in, never heard of that one
Old Jul 23, 2005 | 03:01 PM
Rallyesport
Well, if you don't want the rings to bed in, don't do hard runs for the first hour. It's up to you. There might be different ways to bed in the rings, but one is best.
mk22door
49
Mar 26, 2022 07:15 AM
Chas
Sep 21, 2015 08:57 PM
StephTell
Sep 2, 2015 06:31 PM
Sheepdisease
Aug 30, 2015 09:11 PM
YODI
Aug 30, 2015 01:12 PM
