compression pressure for s2
Old Jul 21, 2005 | 07:34 PM
ashrs's Avatar
ashrs
Default compression pressure for s2
hi guys i have s2 turbo 1660cc with low compression mahle pistons and rings and my mate done a compression pressure test on the engine and it was only reading at 90psi dose this sound to low if so dose this mean the piston rings are fooked?
Old Jul 22, 2005 | 10:01 PM
Rs1's Avatar
Rs1
90psi is low.Surprised its running,lol. Warm the engine up,do another test,wind it over for about 5 secs and equally for each cylinder. Is each cylinder 90??
Old Jul 23, 2005 | 09:15 AM
ashrs's Avatar
ashrs
3 of the cylinders are 90psi but the other one is only 80psi the car is running fine but when we did the test the engine was cold
Old Jul 23, 2005 | 01:55 PM
RSreplica's Avatar
RSreplica
Chris Astley Motorsport
to tell if it is your piston rings that are knackered get an oil can and put 3/4 good squirts of oil in each cylinder before you perform the test, if the reading on the compression tester rises significantly then they need replacing.
the oil has this affect by sealing the rings, will burn off as soon as you start up again.
Old Jul 23, 2005 | 08:15 PM
Rs1's Avatar
Rs1
Tbh m8 90 is far too low. You want to be looking at 10 bar(140psi) minimum.
As above with regards to checking basic ring/bore wear. Each cylinder should rise by the same amount +/- a wee bit.
Old Jul 24, 2005 | 10:16 AM
rsjohn's Avatar
rsjohn
When you test it did you push throttle pedal to floor??
john
Old Jul 24, 2005 | 10:54 AM
ashrs's Avatar
ashrs
no mate i did not push the throttle pedal to the floor why should i have
Old Jul 24, 2005 | 03:00 PM
rsjohn's Avatar
rsjohn
When i was apprentice years ago was told when doing compression test to put pedal to floor when cranking.
On my old low comp rst engine it made 150psi on all cylinders.
john
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
