Atlas axles, wich one is the"one" to have and
which cars has these?
Feel free to tell me all there is no know about Atlas axles if You know and have the time.
GT2
GT2
The atlas was fitted to Capris... depending on which model capri there are different widths.. 48" is a baby atlas, 50" on a mk1 i think and 52" on mk2/3. 52" is the right width for a mk1/2 escoprt with arches. if you get one off a 2.8i special or a brooklands 280 they come with an LSD in them, but it's probably going to be pretty knackered by now. i think the baby axles are specially made rather than standard equipment on anything. 48" is the size you want for an unarched escort
I'm not sure if they were fitted to anything else... definitely not mk1/2 escorts as they all came with the weak English axle. There's another type of axle which looks similar to an atlas (i.e. removal back cover etc) but is actually an English one as well. The was to tell them apart is that the bolt pattern if slightly different. One of them has them offset form the centre but I can't rememebr which and my axle is at retromotorsport so I can't check i'm afraid!
if you get on to Fostek engineering... www.fostek.co.uk they'll be able to help you out if you need one!
Hope that's been of some help!!!
Originally Posted by dingy
Some mk2's came with baby atlas's as standard
top link Wyn!!!!
part answered my question too...
"german production KÖLN axle used on post 08/69 1100&1300 Escorts.
Pre 08/69 german escorts had baby Atlas.
Cheers,
Tepi"
TepiTheFinn usually knows his stuff
Cheers,
Tepi"
I love Atlas,s, I had a Gartrac one (£3500+) in my old Mk2 and it wouldn't break no matter what. I've just got a semi floating Atlas for my new Mk2 and I only paid £1500 for it with a 5:1 ZF diff and it's bracedfand guarded!
They are mega and can take the power, if they don't fit Gartrac can narrow it for between £250 and £700 depending on wether it needs new shafts or not.
my new one
my old one (with my bald mate!)
my new one
2.8 LSD's have a 3.09 CWP which is far to tall...
The correct one costs about 4 grand if that helps LOL
as found in 1600 cc mk4/5 cortina's.
no good at all and not interchangeable with the capri type gears.
puddy
Question pls guys
i believe wheel bearings are different on atlas axles couple different types.
I have a mk2 Capri 3.0 ghia
any way to visually tell what axle I have just incase it’s been changed in 42 years
atm
Sep 1, 2015 04:56 PM
TrevCos
Aug 22, 2015 06:05 PM
