rear conversion S1
Hello peeps can any one tell me what exactly what i would need for a rear disc conversion on my S1. And as any one had the brake pipes replaced with braided right thru there car? is it worth doin or does it make the pedal feel softer?
any help would be gratefull, Andy
Personally mate i'd replace all the rear braking system with that off of a S2 as its all bigger anyhow.
I dont think theres any real gains over a rear disc converstion from the standard stuff, but i could be wrong.
I have the braided lines mate and if anything their better than the copper and certainly wont make the pedal softer, harder is the overall effect.
Not sure if it's the same but i know on a series 2 the rear end tends to enjoy overtaking the front!!!! better option is probably bigger brakes!
i may be wrong but i'm a girl and not mean to know!! anyone know if i'm right or did i just make that up!!
Originally Posted by andyt
Gus i have`nt a clue mate waitin on Billycab to clarify
I bought my braided lines off of Paul Ripley on here, they were off some dog of a S1 he bought to track but ended up stripping it
I'd imagine your looking at about Ł100 or so, can't be anymore than that.
As for the front end, if you want a cheap fix put cossie 4x4 front callipers and cossie 2wd discs on fella. All is a simple bolt on process with the aid of 4x 1mm spacer washers. (as fitted to my cabbie
Job Done
ha ha fair one mate but i take me 11month old son in the car some times
You should be able to get some from Rally Design, they were gonna custom make some for my S3 but Im too lazy to drive down there!
http://www.rallydesign.co.uk/catalog/default.php
Is a Bias valve necessary than??? I have the S2 setup Drilled & Grooved on front and just about to fit rear disk setup on my S1,
Hove much are these valves and where from ??
Thanx - Adi
Thanx - Adi
andy i have a diagram on my pc for the brackets you need to fit sierra rear discs and calipers to your escort, im gonna get some made up at work as i want rear discs on my RSi.
you want a set of brackets?
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
