Boost required to run 400bhp
Old Jul 19, 2005 | 12:42 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Boost required to run 400bhp
As above
Spec i have RS500 intercooler
Ported Head
T34
Group A Headgasket
Group A Pump
Greys (too fit)
Old Jul 19, 2005 | 12:43 PM
Be lucky to make 400bhp to be honest.
Old Jul 19, 2005 | 12:50 PM
Which turbo do you have?
T34 with a 48 housing = NO CHANCE
T34 with a 63 housing = Might scrape it at best part of a couple of bar!
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Why will i be lucky to get 400bhp ??????
Wont be running 22lbs of boost as at present.
Explain Dingy
Old Jul 19, 2005 | 12:52 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
400bhp will be a push but possible.
Fuckloads of boost tho, 2bar+
But boost is good, boost is fun
SPADGE's Avatar
SPADGE
A T34 has a .63 housing or its not a T34!
2 Bar of boost or therabouts
Old Jul 19, 2005 | 12:53 PM
Mine made 405 on dyno with perfect conditions at a held of 26psi.....
In reality it made much less....
Old Jul 19, 2005 | 12:54 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Spadge, its just a T3/4 ie its got a T4 spec (tho small) compressor and a T3 style rear end, regardless of A/R.
Infact RS500 T4s are T3/4s too.
But its not an Escort Cossie spec T3/4 without a .63...
At about 37-38 lbs of airflow you are at the end of the compressor map really for even the T34.63
The CR that you have (standard i assume) is going to struggle to allow you to consume that much air at moderate RPM without getting Det or retarding the timing a lot or running very rich (all of which will lose you power)
Standard cams dont like to rev a lot, so consuming the air with less boost by reving harder isnt an easy option, and anyway for that sort of flow on a T34.63 you actually need big boost to stay on (well off but not by much, lol) the compressor map.
So i agree with dingy, its not a walk in the park.
380 is though on a .63, so it depends on what you mean by 400, do you mean specifically 400 to tell your mates in the pub, or just in the region of 400 to make a nice quick cossie
Old Jul 19, 2005 | 01:00 PM
R4N SS's Avatar
R4N SS
i have blue injectors and mine is 400 so greys should do it - but it is at 2 bar tho
Old Jul 19, 2005 | 01:06 PM
ImaRacing 700's Avatar
ImaRacing 700
2.2bar should get you close on a .63 housing.....
Old Jul 19, 2005 | 01:09 PM
Alvyn's Avatar
Alvyn
28-30 psi with right parts
Old Jul 19, 2005 | 01:11 PM
NMS Badboy^NUTTER^'s Avatar
NMS Badboy^NUTTER^
All of it
Old Jul 19, 2005 | 01:17 PM
Agreed, what else would you call a T34.48 other than a T34?
A lot of people I know in fact call the T34.48 a "T34" and the T34.63 a "T35"
Old Jul 19, 2005 | 01:23 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
woo i got a T35 then
any idea what injectors id need for a 2.0l zetec turbo, wiseco pistons, H section rods to get about 350bhp?
maybe a 50 shot of noz too
cheers
Old Jul 19, 2005 | 01:29 PM
Dan, nitrous wont effect the injectors as it will be a wet kit that you use (if you dont i will personally come round and insert the bottle in you) so it will take care of its own fuelling.
Greens (803) will manage 350bhp but only at slightly higher pressre than the cossie lads run, but thats not an issue to you if you use a decent (044?) pump.
Personally i would use some siemens injectors though, 100 quid a set stateside for some 500-550cc ones which means they will fuel 400bhp+
They open and quick so fast you can still have a lamda sensor and silky smooth idle too
Old Jul 19, 2005 | 02:54 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Comp Ratio is 7.8.1
Im not into Bu-lshit pub figures, my car aint that slow allready with a 115.59mph terminal at the pod, this is on 803s with 22lbs boost.
Turbo has a .48 housing, will i have to fit something like a T38 ??
Cheers Steve
Old Jul 19, 2005 | 02:56 PM
T34.48 you will NOT get 400bhp mate.
About 340 realistically on that CR i suspect.
T38 would be good for well over 400, or better still look at GT series turbos like the GT30???
Fudgey's Avatar
Fudgey
Baby Cheesus
cheers chip, got any links etc to the injectors?
ive got a power boost valve aswell so will be able to adjust fuel pressure
Old Jul 19, 2005 | 02:58 PM
Dan will dig some out mate.
If you only want around 350bhp though, maybe you and this fella should swap exhaust housings???
Less lag for you, and more power for him!
Old Jul 19, 2005 | 03:00 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
well the pistons are good for 700bhp lol and i was just saying around 350 cos i dont know if i can get a ported and big valved head just yet.
Old Jul 19, 2005 | 03:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Supposedly got more than 340bhp now!!!
Must be making a good amount of power to get my terminal
The car is NOT stripped out
Old Jul 19, 2005 | 03:12 PM
Oops i stuck the injector like in the wrong post, lol
http://www.racetronix.com/17113738FM.html
CHECK THE IMPEDANCE IS OK WITH WHATEVER ECU YOU ARE USING!
Old Jul 19, 2005 | 03:13 PM
cossie4i, with that terminal i would guess you have more than 340bhp too mate! daft question but are you positive yours is only a .48 housing?
Old Jul 19, 2005 | 03:17 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ill be using a SECS S8 mate
and fook knows what the impedance of it is
ill ask si
Old Jul 19, 2005 | 03:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Yup only .48 Housing, wanted the car to be very driveable
I want it to have great bottom end and pull like a train at the top
Old Jul 19, 2005 | 03:23 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
fudgeass getr your own thread
Old Jul 19, 2005 | 03:24 PM
cossie4i, sounds liek you got "all that and a bag of chips" then mate!
nice one on that speed with that turbo, who mapped it? sounds like a top job!
Old Jul 19, 2005 | 03:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
A1 Chip but has been modified by Engine Advantages since changing from a 4x4 exhaust manifold too a 2wd manifold.
Gained 14bhp
339lbft, not telling supposed bhp as everyone slags off the figure
But it does the works as you can see from the terminal
Old Jul 19, 2005 | 07:35 PM
simonc's Avatar
simonc
upski
Old Jul 19, 2005 | 08:37 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No More Comments Then
Old Jul 19, 2005 | 08:42 PM
JamesH's Avatar
JamesH
A T34 is a 360BHP Turbo, you can push them a little further say to 370BHP, but on the road that realistically is your limit
Old Jul 19, 2005 | 08:57 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So i have got to get a bigger Turbo then. More Money
Old Jul 19, 2005 | 09:15 PM
RANJ's Avatar
RANJ
402 to be exact
Old Jul 19, 2005 | 09:22 PM
the strut brace's Avatar
the strut brace
he means with a 48 housing
Old Jul 19, 2005 | 09:32 PM
Originally Posted by YUM360
Mark Sheads old Escort had 400bhp on blues running just over 2bar on T34 with a 63 housing
Not on the fooking road it didn't.....
Dyno to incar loose's power LOL
Old Jul 19, 2005 | 09:42 PM
RANJ's Avatar
RANJ
Old Jul 19, 2005 | 09:45 PM
Well u could say depends on ignition and fuel if ya gonna be a smart arse...
Mark's had a escort cos intercooler did he not ? be lucky to make 350.....LOL
