koni suspension wot setting
hi there iv just got a set of konis with avo 25 mm lowering springs to fit on my escort cosworth its got a stare 3 on it wot do i set the shocks to soft med or hard i dont use the car much and dont track it wot you lot think cheers
Yes mate i believe the settings are there to allow the shocks to be 'tightened' up as they wear giving them a new lease of life each time. Most people set them to hard straight away and therefore reduce the life of them
Mine are on soft and they do the trick !!
truffleshuffle
Sep 10, 2015 09:35 PM
