2wd brake callipers
Old Jun 23, 2004 | 09:38 PM
CraigN's Avatar
CraigN
Default 2wd brake callipers
how the hell do i push the pistons back when changing disks and pads on the front callipers ?
ive taken the cap off the resevoir and i have been trying with some fat mole grips and they hardly moving
anyone help me out ?
also how do i get my turbo damper off my turbo
Old Jun 23, 2004 | 09:39 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
they need 2 be screwed back in with the correct tool m8
Old Jun 23, 2004 | 09:41 PM
CraigN's Avatar
CraigN
oh ffs were can i get one of these?
Old Jun 23, 2004 | 09:42 PM
CraigN's Avatar
CraigN
btw im talking about front callipers
not rears
i know the rears have to be screwed in do the fronts ????
Old Jun 23, 2004 | 09:43 PM
Paul's Avatar
Paul
burton power sell the wind back tools
Old Jun 23, 2004 | 09:44 PM
Rs Gus's Avatar
Rs Gus
no m8 but they r probably seized then by the sounds the other thing u can try is just open the bleed screw and release them that way but the brake caliper will need re bleading m8
Old Jun 23, 2004 | 09:48 PM
CraigN's Avatar
CraigN
i tried opening bleed nipple still no movement
i will buy the piston spreader from burton power as that looks like a propper tool for the job
then will have it for future use if still dont work will need to sort my callipers out
Old Jun 23, 2004 | 09:59 PM
Rs Gus's Avatar
Rs Gus
i would sudjest if u opend the bleed screw and they DIDNT MOVE THEY R FOOKED SIEZED LOL buy some new 1's
Old Jun 23, 2004 | 10:02 PM
CraigN's Avatar
CraigN
these were workign fine 2 months ago
and they look like they were reconned not long ago
Old Jun 23, 2004 | 10:07 PM
CraigN's Avatar
CraigN
my callipers have 2 bleed nipples
looking on burton power website the picture on there shows the 2wd callipes with one bleed nipple
i only tried opening 1 nipple lol
Rs Gus's Avatar
Rs Gus
[quote="CraigN"] these were workign fine
i like that word were now arnt
Old Jun 23, 2004 | 10:11 PM
RSrussell's Avatar
RSrussell
you are a fookin nipple
Old Jun 23, 2004 | 10:12 PM
CraigN's Avatar
CraigN
not funny
Old Jun 23, 2004 | 10:13 PM
Rs Gus's Avatar
Rs Gus
my aps have 2 nipples and?
Old Jun 23, 2004 | 10:15 PM
CraigN's Avatar
CraigN
bunch of coonts u lot
i want my cossie back on the road and its being fooooorking gaylordish
Old Jun 23, 2004 | 11:52 PM
Uncle Henry's Avatar
Uncle Henry
calipers must be seized - is there any splits/perishing on the dust covers around the pistons?
they should push in easily especially with the bleed nipples undone
Old Jun 24, 2004 | 07:32 AM
alan rainbow's Avatar
alan rainbow
whats up with a g clamp instead of spending money on somthing you dont need
Old Jun 24, 2004 | 07:39 AM
Spiky's Avatar
Spiky
sadly, they are right, if you can push them back, they are seized
i have 1 piston like that on one of mine.
Ian @ godspeed soon sorted that out
CraigN's Avatar
CraigN
just had another look one of the ruber seals arround the piston has come away from the calliper
Old Jun 24, 2004 | 07:45 AM
Spiky's Avatar
Spiky
shit luck dude
Old Jun 24, 2004 | 09:28 AM
Ian Godney's Avatar
Ian Godney
Craig
If your stuck bring them over to me and I will sort them out while you wait , its not too far from Bristol , I keep the seals in stock
Cheers Ian
Old Jun 24, 2004 | 09:39 AM
3drstretch's Avatar
3drstretch
There you go Craig and you can pick up RobS exhaust at same time.It only about 40 mins from his house to Ian's.
3drstretch's Avatar
3drstretch
Old Jun 24, 2004 | 10:46 AM
Rene's Avatar
Rene
top man ian
that's why i am rebuilding mine as well
Old Jun 24, 2004 | 10:55 AM
CraigN's Avatar
CraigN
ian whats your number
are you there on monday ? what time ytou about till
number ill call you
Old Jun 24, 2004 | 11:04 AM
Rene's Avatar
Rene
number ill call you
(01656) 660899
CraigN's Avatar
CraigN
Old Jun 24, 2004 | 11:14 AM
CraigN's Avatar
CraigN
ian you have voicemail
Old Jun 24, 2004 | 11:21 AM
Rene's Avatar
Rene
ian is a busy man but i am sure he can sort u out
Old Jun 24, 2004 | 11:23 AM
Ian Godney's Avatar
Ian Godney
I will be here 6am till 7pm monday , there's a map on my web site , just call up , I can sort them out for you then
Old Jun 24, 2004 | 11:48 AM
Spiky's Avatar
Spiky
6am
Old Jun 24, 2004 | 01:12 PM
CraigN's Avatar
CraigN
ian u open saturdays
what is your website ?
Old Jun 24, 2004 | 01:52 PM
Spiky's Avatar
Spiky
www.godspeedbrakes.co.uk
Old Jun 24, 2004 | 03:10 PM
Ian Godney's Avatar
Ian Godney
I am there every saturday 8am till 6pm unless I'm away rallying , I will be there until about 2-30 this saturday as I'm off to the midlands to have my laser jammer , sorry garage door opener set up
Old Jun 24, 2004 | 04:33 PM
CraigN's Avatar
CraigN
ian if your there from 8am on saturday i will come down then
i see on ure site you clean them all up and paint them nice pretty colours
is that done all in house and can be done in a day or just the seals that can be done in a day ?
Old Jun 24, 2004 | 04:35 PM
CraigN's Avatar
CraigN
Old Jun 25, 2004 | 06:16 AM
Ian Godney's Avatar
Ian Godney
Just the seals can be done the same day , if you want them blasted off and sprayed that is a 2 day job as the paint has to dry before they can be rebuilt , I will call you later to see if I can do them in the morning , I am working on 2 kits which the customers are oicking them up mid day tomorrow , so as long as they are finished I can do yours , if not I will have to do them monday , unless you do want them sprayed as you could drop them up sat , and I can post them back to you monday ?
Cheers Ian
mark r
Sep 29, 2015 07:27 PM
Sp3no
Sep 27, 2015 07:23 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focus2351
Sep 9, 2015 09:33 PM
