media & powerdvd problem
Old Jul 18, 2005 | 07:19 PM
SS1's Avatar
SS1
Default media & powerdvd problem
just got my pc back all upgraded
but the fooker now wont play movies through media9 or power dvd
well it does but the colours all distorted ???
ive tried changing the hue and saturation but to no avail
any ideas heres the pcs specs
Your System Game Requirements
Operating System Microsoft Windows XP Professional Service Pack 2 (Build 2600) Windows XP
System Memory 1024.5 512.0
Processor Speed 3215.6 1700 Mhz (1.7 GHz)
DirectX Version (Get Updates) 9.0c 9.0c
Display Device (Get Drivers) NVIDIA GeForce FX 5600
Display Memory 128.0 128.0
Display Driver 6.14.10.7772
Sound Device (Get Drivers) Realtek AC97 Audio
Sound Driver 5.10.5300
Operating System Information
Internet Explorer Information
Version 6.00.2900.2180
Background Processes 35/35
System
Process smss.exe
Process winlogon.exe
Process services.exe
Process lsass.exe
Process svchost.exe
Process svchost.exe
Process spoolsv.exe
Process CCEVTMGR.EXE
Process NAVAPSVC.EXE
Process NISUM.EXE
Process nvsvc32.exe
Process vsmon.exe
Process CCPXYSVC.EXE
Process SymWSC.exe
User
Process explorer.exe
Process ctfmon.exe
Process SOUNDMAN.EXE
Process zlclient.exe
Process ccApp.exe
Process dragdiag.exe
Process point32.exe
Process PDVDServ.exe
Process msmsgs.exe
Process ycommon.exe
Process ybrwicon.exe
Process ybrowser.exe
Process EasyInfo.exe
Other
Process [System Process]
Process System
Process csrss.exe
Process svchost.exe
Process svchost.exe
Process svchost.exe
Process alg.exe
Process wmiprvse.exe
System Device Information
Processor 1/1
Intel Intel(R) Pentium(R) 4 CPU 3.20GHz 3215.6
FPU True
MMX True
SSE True
SSE2 True
3D Now False
3D Now Plus False
SSE-MMX False
TSC True
IA64 False
APIC True
ACPI True
MTRR True
CMOV True
Serial False
Thermal True
Extended Features
Hyper Threading Support True
MMX Plus False
Logical Processors Per Physical 2
Voltage ID False
Frequency ID False
Temperature Sense Diode False
Memory
System Total 1024.5
Virtual Total 2047.9
Pagefile Total 2462.1
Snapshot
System Available 775.4
Virtual Available 2004.2
Pagefile Available 2211.8
Percent Load 24
Mass Storage Devices
Drive A:\
Type Removable
Letter A:\
VolumeName N/A
FileSystem N/A
TotalSpace 0 Bytes
FreeSpace 0 Bytes
Capabilities
Read-Only False
Compressed False
Supports Compression False
Supports Case-preservation False
Supports Case-sensitive filenames False
Supports Encryption False
Supports Named Streams False
Supports Object IDs False
Supports Persistent ACLS False
Supports Quotas False
Supports Reparse Points False
Supports Sparse Files False
Supports Unicode False
Drive C:\
Type Fixed
Letter C:\
FileSystem NTFS
TotalSpace 232.9 GB
FreeSpace 216.8 GB
Capabilities
Read-Only False
Compressed False
Supports Compression True
Supports Case-preservation True
Supports Case-sensitive filenames True
Supports Encryption True
Supports Named Streams True
Supports Object IDs True
Supports Persistent ACLS True
Supports Quotas True
Supports Reparse Points True
Supports Sparse Files True
Supports Unicode True
Drive D:\
Type Fixed
Letter D:\
FileSystem NTFS
TotalSpace 114.5 GB
FreeSpace 114.4 GB
Capabilities
Read-Only False
Compressed False
Drive E:\
Type CD / DVD Drive
Letter E:\
VolumeName N/A
FileSystem N/A
TotalSpace 0 Bytes
FreeSpace 0 Bytes
Capabilities
Read-Only False
Compressed False
Drive F:\
Type CD / DVD Drive
Letter F:\
VolumeName WHITE_NOISE
FileSystem UDF
TotalSpace 4.4 GB
FreeSpace 0 Bytes
Capabilities
Read-Only True
Compressed False
Monitor Information 1/1
Monitor Name SONY CPD-E220/E220E
Refresh Rate 60 Hz
Network Adapter Information 1/1
Network Adapter Name WAN (PPP/SLIP) Interface
IP Address 81.155.195.11
Subnet Mask 255.255.255.255
Gateway 81.155.195.11
Primary WINS Server N/A
DHCP N/A
Media Device Information
DirectX Information
Version 9.0c
Long Version 4.09.0000.0904
Display Device 1/1
NVIDIA GeForce FX 5600 Local Memory: 128.0 Driver Version: 6.14.10.7772
Device
Description NVIDIA GeForce FX 5600
Manufacturer NVIDIA Corporation
GUID D7B71E3E-4052-11CF-F373-FBA00EC2CD35
Driver
Version 6.14.10.7772
Module nv4_disp.dll
Date 6-15-2005
Memory
Total 128.0
Available 126.0
Non-Local 118.0
Texture 244.0
Sound Device 1/1
Realtek AC97 Audio Driver: 5.10.5300
Device
Description Realtek AC97 Audio
Manufacturer Realtek Semiconductor Corp.
GUID BD6DD71A-3DEB-11D1-B171-00C04FC20000
Driver
Version 5.10.5300
Module ALCXWDM.SYS
Date 8-15-2003
Capabilities
Max 3D Buffers 33
Supports Mono Output True
Supports Stereo Output True
ANY HELP WOULD BE COOL
Old Jul 20, 2005 | 10:34 AM
DanRSturbo's Avatar
DanRSturbo
What's the video clip ? Avi ? MPEG ? Might be a codec issue, download the div x codec from www.divx.com and see if it improves, alos update media player to version 10
Old Jul 20, 2005 | 09:22 PM
SS1's Avatar
SS1
its a driver issue think its been sorted now from
Adam_BlackRS
Found a fix....
Install the latest drivers again 77.72 and do this after......
Open the NV Control Panel and Choose "Colour Correction" in the left hand panel, then in the right hand panel click on the drop down box under "Apply Color Changes To:" and selct the option "All." Finally click on the drop down box in the bottom left hand side of the panel under "Color Profile" and select "Advanced Mode", apply the changes and your done
pesky battlefield2 STRIKES AGAIN
updated navidia drivers
Old Jul 21, 2005 | 04:08 PM
aduz's Avatar
aduz
who is that girl with the nice arse??
Billy_RS
16
Oct 11, 2025 09:41 PM
steerfromdarear
28
Jan 29, 2016 06:14 PM
Indyrs
20
Sep 1, 2015 09:04 AM
track.focus'd
Aug 12, 2015 05:53 PM
slammedorion
21
Aug 6, 2015 11:38 AM
